• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *scottl
    file conversion to inventor
    120 Views, 3 Replies
    10-29-2008 04:48 AM
    can someone convert some catia files to inventor for me? there are 4 parts
    ea. like
    14-15 meg. camshafts. the extension of these parts is *.CATpart
    Scott
    win xp 2002
    xeon cpu 3.00 GHz
    2 gig of ram
    AutoCAD 2008
    AutoCAD 2009
    nvida quadro fx3500
    Inventor 2008 sp2
    Inventor 2009 sp1
    Please use plain text.
    *Dennis Jeffrey
    Re: file conversion to inventor
    10-29-2008 06:43 AM in reply to: *scottl
    I can do that. If you need a private FTP, email me at
    djeffrey@teknigroup.com
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert.
    Instructor/Author/Sr. App Engr.
    AIP 2008 SP2, AIP 2009-SP1 PcCillin AV
    HP zv5000 AMD64 2GB - Geforce Go 440, Driver: .8185
    XP Pro SP2, Windows XP Silver Theme
    http://teknigroup.com
    Valued Contributor
    04-23-2012 08:47 AM in reply to: *Dennis Jeffrey
    Do you need to save the catpart as (?) to import it into Autocad ?
    mark
    Everything in existence was first an Idea
    Autodesk Plant 3D Premium 2012
    Autodesk MEP 2012
    HP 3.2 Mhz CPU 16 ram
    1TB 7200 rpm SATA 3Gb/s hard drive
    2GB DDR3 NVIDIA GeForce GT 530
    HP 2311x 23" LED Monitor
    04-23-2012 08:59 AM in reply to: mgalicki
    mark
    This doesn't make sense.
    The software has changed in 4 years.
    AutoCAD will now import Catia files directly.
