• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    face sketch
    244 Views, 7 Replies
    01-16-2013 05:46 AM
    I created a round face for use in a pressure gauge.I am not using a Decal for the face but instead want to use a sketch/sketches to show all the numbers,increments etc..etc..
    From the picture/file supplied how do i do the following
    1. Use a sketch/sketches to display all the features for the gauge face.I used a sketch but it has the construction lines still visible
    2. Make the line thickness larger and the color RED
    3. How do i fill in the squares with solid color ( where the numbers go around the face)
    Is there a much more better way then what i have suggested.....is this how you would create the face features if not using Decal
    Kind Regards
    Simon
    Please use plain text.
    Valued Contributor
    Re: face sketch
    01-16-2013 06:00 AM in reply to: simon_toaldo
    You could extrude it by a very small amount (text, too), and change the color of the extruded feature through its properties menu.
    -Autodesk Inventor Professional 2012
    Valued Contributor
    Re: face sketch
    01-16-2013 07:38 AM in reply to: simon_toaldo
    Can this be done with sketches also....I would somehow prefer to sketch all the face identities
    *Expert Elite*
    Re: face sketch
    01-16-2013 07:44 AM in reply to: simon_toaldo
    See attached.
    How is it done on the real part?
    I might use sketch to Split the faces and then change the color Properties of the faces.  This will leave everything flush without creating tiny extrusions - but would be a bit more work as text would need to be sketched.
    You could change the sketch Properties, but that doesn't take care of the "fill" unless the line thickness meets.
    As far as construction line visibility you could Project Geometry only the desired lines to a new sketch and turn off visibility of the generating sketch and then change the Properties of the lines.
    Valued Contributor
    Re: face sketch
    01-17-2013 06:10 AM in reply to: simon_toaldo
    Thank you
    I now try sketch and use Extrude....Please see sketch as i used a circular pattern but for some reason the sketch does not lign up..i use 10 features at 320 degrees...why does this not pattern correctly
    Simon
    *Expert Elite*
    Re: face sketch
    01-17-2013 06:28 AM in reply to: simon_toaldo
    I don't use Sketch Patterns where Feature Patterns would be more efficient.
    (Edit your Sketch8 then Right Mouse Button > Show All Constraints.)
    Valued Contributor
    Re: face sketch
    01-17-2013 07:18 AM in reply to: simon_toaldo
    Would you recommend i do the sketch/extrusion ffor the circle shape and then start new sketch for the increment ,extrude and then use Feature Patttern for 10 increments
    Valued Contributor
    Re: face sketch
    01-18-2013 05:27 AM in reply to: simon_toaldo
    I did use the sketch/extrude feature followed by sketch/extrusion/circular pattern....On the circular pattern i used 10 increments @ 300 degrees....why does the 10th increment not line up at the 10th position...have i got the maths wrong?
