• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    jeroenwm
    dynamic stress simulation
    132 Views, 2 Replies
    10-14-2012 08:13 AM
    is their a possibility to applay stress like dynamic i have a shaft that has a pully on it , its conectet on an old way
    not with a tight fit so it shrinks on it but it works wit a small cut in the shaft where its bolted with just a tiny metal plate.
    at this place will be a stress concentration and i wanne see how the noth effect is when their is a dynamic load on it cause if i put a static load on it i know the shaft can handel it but i real life it has broken couple of times so this is what i want to investigate shaft.png
    i hope you understand my question and help me  kind regards
    Please use plain text.
    *Expert Elite*
    Re: dynamic stress simulation
    10-14-2012 10:30 AM in reply to: jeroenwm
    Can you test the assembly in the Dynamic Simulation environment and output time-steps to FEA for Motion Loads Analysis?
    I don't see any twisting forces on your shaft - how is the shaft used in an assembly?
    jeroenwm
    10-14-2012 12:31 PM in reply to: JDMather
    on the shaft is a pully that guides a  chain but somtimes the  chain blocks and so the motor + reductor builds up tention until it releases . i asume that the worst place is when the pully is in that direction when the pulling force is in a perpendicular direction with the flat surface  so the shaft is getting "pulled open" if you get what i mean . i think multiple times of this force will tear the shaft at the red line in the picture. this is how i wanne simulated it
    can i do this with inventor or do i need the multi physics for it ?
    in other words their isnt going to be a twisting force cause the chain guides trough it only the friction between the chain and pully is going to make it turn around but this forces are neglecteble
    Kind regards
