• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    dimensioning to Z shape implied intersections
    135 Views, 2 Replies
    11-13-2012 08:13 AM
    Looked through the help and found nothing, then did a search here and found nothing.
    I am needing to put a horzontal dimension from the implied intersections of a "Z" shape.
    In the attached screen shot, I have a question mark at the dimension I'm needing.
    I have tried the RMB/Intersection in different ways, but none giving me the dimension
    I'm needing.
    How do I go about getting this dimension?
    Thank you very much for your help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    ACAD Mechanical 2013
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: dimensioning to Z shape implied intersections
    11-13-2012 09:20 AM in reply to: sps_cad_guy
    To accomplish this task do the following:
    1. Select Line 1
    2. RMB > Intersection
    3. Select Line 2
    4. Select Line 3
    5. RMB > Intersection
    6. Select Line 4
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Valued Contributor
    11-13-2012 10:16 AM in reply to: mpatchus
    Perfect!
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
