• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    carey.olson
    dimension from quadrant of circle to appt intersection on a cirlce
    193 Views, 2 Replies
    01-10-2013 12:34 PM
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: dimension from quadrant of circle to appt intersection on a cirlce
    01-10-2013 12:56 PM in reply to: carey.olson
    Carey,
    Welcome to the forum.
    Take a look at this link.  See if it helps you.
    http://forums.autodesk.com/t5/Autodesk-Inventor/Tangent-Dimensioning-of-Arcs/td-p/3317169
    Best Regards,
    Scott McFadden
    (Colossians 3:23-25)
    *Pro
    sbixler
    01-11-2013 04:40 AM in reply to: carey.olson
    My solution below is in Inventor 2013, but since you didn't tell us what version you're using, I don't know if you can open it.
    This isn't as easy as it ought to be, but here's how I did it (see attached).  I created a view sketch, projected the two arcs, and created an arc concentric with the big "circle" as an extension to show the complete circle (set to the Dimension layer).  I then put in a Sketch-Only line between the arc centers, then a normal line tanget to the sketched arc and perpendicular to the previous line.  This last line is purely for something to dimension to.  I exited the sketch, then created a dimension between the tangent line just placed and the quadrant of the small arc.  Then I went back into the sketch and changed that tangent line to Sketch Only so it is not visible.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
