• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Numan, Gary
    Re:
    11-06-2002 10:46 PM in reply to: *Numan, Gary
    Thanks for the AVI Sean, that really cleared it up. Pretty sweet.
    One more thing, only one I promise: how do you add a member to the set to
    get the other intersect?
    Enjoy,
    Gary Numan
    "Sean Dotson" wrote in message
    news:ECD94EED57E62665457871D1D0D9E07D@in.WebX.maYIadrTaRb...
    > Worked for me. You have to zoom in a bit as the intersection is very near
    > the edge of the tube and it wants to snap to that first. I simply put in
    > two bisectors and then hovered over one then the other and then followed
    the
    > dotted like path of the second till they met and clicked.
    > I will put and AVI files in the CF to illustrate.
    > Sean Dotson, PE
    > http://www.sdotson.com
    > ...sleep is for the weak..
    > "Gary Numan" wrote in message
    > news:0604A72AA53C169FCEB8C0AD61FAE370@in.WebX.maYIadrTaRb...
    > > Ok I posted a model and a drawing example in the customer files folder.
    > > Wanna take a stab at it?
    > > Enjoy,
    > > Gary Numan
    > > news:CF2FE9A9050B9CE16612169C4B1FFF4A@in.WebX.maYIadrTaRb...
    > > > Should work, I just tried in on two sketched lines in an idw and it
    > > worked.
    > > > Hover over the first line then the second and follow the path of the
    2nd
    > > > until you get to the intersection point and the dotted lines should
    > > connect.
    > > > Sean Dotson, PE
    > > > news:E2BD2BFA5F600D5EDA0EEE7EF61568A5@in.WebX.maYIadrTaRb...
    > > > > Good for the intersect of two edges. How about in this case where
    two
    > > > > centerlines are intersecting?
    > > > > Enjoy,
    > > > > Gary Numan
    > > > > "Kent Keller" wrote in message
    > > > > news:2D4A65D3593899B6EE54CE9491B42CED@in.WebX.maYIadrTaRb...
    > > > > > Actually you can do it with ordinates also
    > > > > > http://www.mymcad.com/inventorfaq_answer5305.html
    > > > > > Kent
    > > > > > Member of the Autodesk Discussion Forum Moderator Program
    > > > > > news:9A9B3B288C3877BB8BD65FE2DDD621F4@in.WebX.maYIadrTaRb...
    > > > > > > If you could live with a regular dim instead of an ordinate
    there
    > is
    > > a
    > > > > way:
    Please use plain text.
    *Dotson, Sean
    Re:
    11-06-2002 10:51 PM in reply to: *Numan, Gary
    RMB (right mouse button) on the current dim and select add member.
    Sean Dotson, PE
    news:C8D0F85619A2AA309D11E05AF835DB0B@in.WebX.maYIadrTaRb...
    > Enjoy,
    > Gary Numan
    near
    in
    > the
    > > Sean Dotson, PE
    folder.
    > > > Enjoy,
    > > > Gary Numan
    > > > worked.
    > 2nd
    > > > connect.
    > > > > Sean Dotson, PE
    > two
    > > > > > Enjoy,
    > > > > > Gary Numan
    > > > > > > Kent
    > there
    > > is
    > > > a
    > > > > > way:
    *Numan, Gary
    Re:
    11-06-2002 11:12 PM in reply to: *Numan, Gary
    Forgive my unclear question - but I seem to be having no luck in actually
    adding the member at the other intersect.
    Enjoy,
    Gary Numan
    news:A01B2636AB0939C676BA3626BF1FB411@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    to
    > > Enjoy,
    > > Gary Numan
    > near
    > in
    followed
    > > the
    > > > Sean Dotson, PE
    > folder.
    > > > > Enjoy,
    > > > > Gary Numan
    it
    > > > > worked.
    the
    > > 2nd
    should
    > > > > connect.
    > > > > > Sean Dotson, PE
    where
    > > two
    > > > > > > Enjoy,
    > > > > > > Gary Numan
    > > > > > > > Kent
    > > there
    > > > is
    > > > > a
    > > > > > > way:
    *Dotson, Sean
    Re:
    11-07-2002 01:03 AM in reply to: *Numan, Gary
    Hmm. you are right that does not seem to work (the lines won't project).
    Try using the ordinate dim (not ordinate set command) so you can place each
    one individually. Refer to the help on how to use this command. You must
    place a 0,0,0 mark then place your dims.
    Sean Dotson, PE
    news:249F5C3B65DBC56355ACB219D2C0E8F8@in.WebX.maYIadrTaRb...
    > Enjoy,
    > Gary Numan
    > > Sean Dotson, PE
    > to
    > > > Enjoy,
    > > > Gary Numan
    very
    > > near
    put
    > > in
    > followed
    > > > the
    > > > > Sean Dotson, PE
    > > folder.
    > > > > > Enjoy,
    > > > > > Gary Numan
    > it
    > > > > > worked.
    > the
    > > > 2nd
    > should
    > > > > > connect.
    > > > > > > Sean Dotson, PE
    > where
    > > > two
    > > > > > > > Enjoy,
    > > > > > > > Gary Numan
    > > > > > > > > Kent
    ordinate
    > > > there
    > > > > is
    > > > > > a
    > > > > > > > way:
    *Keller, Kent
    Re:
    11-07-2002 01:51 AM in reply to: *Numan, Gary
    Somewhere I got lost in this thread.... but if you want to add a dim to a set and have it
    go to the implied intersection, just add it at any vertex close, and then after placing
    pick on the dim, and grab the yellow dot and drag it using the same method as Sean showed
    in the AVI
    Kent
    news:8971735326415CB47066A59EA0D823A9@in.WebX.maYIadrTaRb...
    *Numan, Gary
    Re:
    11-07-2002 02:00 AM in reply to: *Numan, Gary
    Thanks for the help Sean. Yes the ordinate command works to place subsequent
    or individual ordinate dimensions. I'll get this yet, with a little help
    from my friends at autodesk.inventor.*
    Enjoy,
    Gary Numan
    each
    > Sean Dotson, PE
    actually
    > > Enjoy,
    > > Gary Numan
    > > > Sean Dotson, PE
    set
    > > to
    > > > > Enjoy,
    > > > > Gary Numan
    > very
    > > > near
    > put
    > > > in
    > > followed
    > > > > the
    > > > > > Sean Dotson, PE
    > > > folder.
    > > > > > > Enjoy,
    > > > > > > Gary Numan
    and
    > > it
    > > > > > > worked.
    of
    > > the
    > > > > 2nd
    > > should
    > > > > > > connect.
    > > > > > > > Sean Dotson, PE
    > > where
    > > > > two
    > > > > > > > > Enjoy,
    > > > > > > > > Gary Numan
    > > > > > > > > > Kent
    > ordinate
    > > > > there
    > > > > > is
    > > > > > > a
    > > > > > > > > way:
    *Dotson, Sean
    Re:
    11-07-2002 02:04 AM in reply to: *Numan, Gary
    Kent the RMB add member does not show the dotted trails to find the
    intersection. Your suggestion of placing it then dragging it to the right
    spot would likely work however. I suggested the ordinate dim (not set)
    command so that you could place in one shot.
    Sean Dotson, PE
    news:18C15A89CEC000D16DF1F001D4B945E6@in.WebX.maYIadrTaRb...
    set and have it
    after placing
    as Sean showed
    > in the AVI
    > Kent
    *Keller, Kent
    Re:
    11-07-2002 02:30 AM in reply to: *Numan, Gary
    Yeah I realize that, but I hate using the (non set) ordinate command, and would rather do
    the two step rather than deal with it. 8^)
    Kent
    *Dotson, Sean
    Re:
    11-07-2002 02:57 AM in reply to: *Numan, Gary
    What you and I do and what a new user SHOULD do are often two different
    things Do as I say not as I do
    Sean Dotson, PE
    news:71C018B26FD0D0CD8474742A90817511@in.WebX.maYIadrTaRb...
    would rather do
    > Kent
