• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    different iPart instances in drawing that dont update with model
    48 Views, 0 Replies
    11-23-2009 08:19 AM
    I have a an iPart with a lot of instances in it and i want to insert different ones into my drawing in different sheets. the problem is as soon as the model is changed to another instance the drawing updates. Now i've done this before in the past and I had to create a derived part from the instance i wanted then place that in there. I thought AutoDesk had changed this where you could actually pick the instance you want of your iPart (like how you pick a differnt LOD) place that in your drawing but i have yet to find it. Also let me say that these are Flat Pattern parts in need to put in my drawings.
    I did a search on the knowledge base and didnt find anything, although it may be there.
    thanks for any help in advance,
    Mike Edited by: mikew@dunbarton.com on Nov 23, 2009 5:42 PM
    Please use plain text.
