• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    different degree flange question.
    116 Views, 2 Replies
    01-16-2013 08:58 AM
    I've attached a pdf of a part I'm making the flat pattern for.
    The pdf is from our customer, and I already know it's not shown correctly, views wrong, etc.
    One bend is 90 degrees and the other is 88 degrees.
    What I'm having trouble with, is when I go to put flanges on my part, the corner does not come out as it should be.
    The long flange does not have the 2 degrees of material added to it, and even though I have told it to tear the corner, it still puts a big relief when I put the second flange on.
    I have searched the help and can't seem to find what I'm looking for.
    Thank you very much for your help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    ACAD Mechanical 2013
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: different degree flange question.
    01-16-2013 09:17 AM in reply to: sps_cad_guy
    Hi sps_cad_guy,
    Attached is a quick example file.
    There might be more efficient ways to get the same result but this is what came to mind, and should serve as an example of some of the tools that can be used.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    01-16-2013 09:20 AM in reply to: Curtis_Waguespack
    Thank you so much Curtis!
    That looks perfect.
    I knew there had to be an easier way to do it that what I was doing.
    Thanks again for your help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
