• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Member
    kevinzaskowski
    Accepted Solution
    design window
    100 Views, 4 Replies
    10-12-2012 04:49 AM
    i am doing a presentation, but don't want the gray background.  how do i change the color?  thanks
    Please use plain text.
    *Pro
    Re: design window
    10-12-2012 04:52 AM in reply to: kevinzaskowski
    What version of Inventor (always provide this in your first post!)?  Have you tried Application Options > Colors tab?
    Active Member
    kevinzaskowski
    Re: design window
    10-12-2012 05:03 AM in reply to: sbixler
    autodesk inventor 2012
    *Pro
    Re: design window
    10-12-2012 05:13 AM in reply to: kevinzaskowski
    Making a presentation of what?  Powerpoint slides of Inventor images?  Inventor assembly live on the screen?
    Did you try changing color schemes?  What do you want it to look like?
    You haven't so far given nearly enough information to allow anyone to help you.
    Active Member
    kevinzaskowski
    Re: design window
    10-12-2012 05:33 AM in reply to: sbixler
    Thank you.  It was under the "application option" that you described above.  Thanks!
