• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    defining range of motion
    64 Views, 2 Replies
    12-05-2002 10:28 PM
    hi all - i wanted to know if there is any way to limit the range of motion of a part. i need to limit the range of motion of a piston to be four inches of travel. currently the picton is constrained to be concentric with the housing it is in, but once the assembly is put together the piston can be dragged through the housing . . . .
    Thanks so much -
    Please use plain text.
    *Fulford, Drew
    Re: defining range of motion
    12-05-2002 10:38 PM in reply to: JohnHerbert
    There is a workaround way defined at my site.
    See Inventor tips & tricks 2011 http://www.mymcad.com/
    I havent tested to see if this still works in R6
    - drew
    Drew Fulford B.A.Sc. Systems Engineer
    Solid Caddgroup Inc. Burlington, Ontario
    Tel: (905)331-9670, Fax: (905)331-7280
    Corporate: http://www.solidcadcam.com/
    Member of the Autodesk Discussion Forum Moderator Program
    Visit my MCAD website @ http://www.mymcad.com/
    "JohnHerbert" wrote in message
    news:f12a34a.-1@WebX.maYIadrTaRb...
    > Thanks so much -
    *Dotson, Sean
    Re:
    12-05-2002 10:41 PM in reply to: JohnHerbert
    "I havent tested to see if this still works in R6"
    It does..
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    http://www.sdotson.com/faq.html
    "Drew Fulford" wrote in message
    news:57EFF194DFC2C562E9011DB2C6E286E1@in.WebX.maYIadrTaRb...
    > - drew
    motion
    inches
    > > Thanks so much -
