• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: cut and paste
    01-14-2013 07:30 AM in reply to: Cadmanto
    Cadmanto wrote:
    I have tried numerous time to select a part in the assembly tree and do a ctrl-C and then a ctrl-V
    Didn't read through this entire thread - I assume you have found out that you can Ctrl drag copies of parts from assemby tree to graphics window.
    Inventor Professional 2014 Edu 64-bit
    Please use plain text.
    Curtis_Waguespack
    Re: cut and paste
    01-14-2013 07:54 AM in reply to: Cadmanto
    and it has never worked for me.
    Hi Cadmanto,
    If you select the target part in the browser and press CTRL + C on the keyboard, then click in the graphics area and then press CTRL + V on the keyboard it should work. Keep in mind that the click in the graphics area provides the insertion point as well.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Employee
    stanislav.sedlak
    Re: cut and paste
    01-15-2013 12:47 AM in reply to: jsmith923
    you are right, I see the same behaviour on my machine.
    I have logged an issue (DID1489576 ) for this topic to our internal database so people from Autodesk can take a look.
    Thanks for reporting this issue!
    Stanislav Sedlak
