• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Terry__Close
    curved bend in sheet metal part
    366 Views, 6 Replies
    12-26-2012 01:18 AM
    Hi
    Can a curved section with bend be applied to sheet metal part.I make extrusion for easier clarity.I am wanting to place the curved section (extrusion for demonstration purpose) with bend in sheet metal part but all created in the sheet metal environment.
    Is this possible?
    TC
    Please use plain text.
    Re: curved bend in sheet metal part
    12-26-2012 04:53 AM in reply to: Terry__Close
    Use Contour Roll.
    I would do the rolled feature first.
    Valued Contributor
    Terry__Close
    12-27-2012 04:10 AM in reply to: Terry__Close
    OK
    I did some searching and came up with the attempt attached.Have i done this correctly?
    CAn this part now be flattened?
    I do not use sheet metal that often but will make efforts to learn more
    Terry
    Valued Contributor
    Terry__Close
    12-28-2012 07:00 AM in reply to: Terry__Close
    pls see attached
    can this part be flattened?
    12-30-2012 06:09 AM in reply to: Terry__Close
    I have not attempted your part yet, but after seeing your attempt I wish to revise my earlier statement.
    Looks like if this is to work the Contour Roll should be created after the Face.
    Valued Contributor
    Terry__Close
    01-01-2013 06:44 AM in reply to: Terry__Close
    JD did you attempt to model this please.Would like to see correct solution
    Terry
    Valued Contributor
    Terry__Close
    01-08-2013 04:55 AM in reply to: Terry__Close
    OK i have placed the Contour Roll after the face but still does not flatten.What am i doing wrong here?
    Terry
