• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Mike686
    create workplane independant of origin workplane
    195 Views, 6 Replies
    12-17-2012 09:45 AM
    hi, i have a question about workplane..
    i was reading mastering inventor, the part about ifeatures
    he suggest to avoid the use of origin work plane
    i read somewhere the same about icopy tool..
    my question is what's the best way to create a workplane independant of origin workplane?
    Product Design Suite 2013
    Please use plain text.
    Valued Mentor
    japike
    Re: create workplane independant of origin workplane
    12-17-2012 11:31 AM in reply to: Mike686
    That depends on what you are trying to accomplish. Sometimes I use an offset workplane to define a workplane a certain distance from a surface or another workplane. Sometimes I use an edge or two to define a workplane. Sometimes I use sketch geometry to define a workplane. What are you trying to accomplish?
    Peace,
    Jeff
    Inventor 2013
    *Expert Elite*
    cbenner
    12-17-2012 11:34 AM in reply to: Mike686
    I'm not sure exactly what you are trying to do, but I prefer to use origin planes for feature creation whenever possible.  One thign I cannot stand is when a user work plane is created on top of an origin plane.  It's redundant and muddys up the part.  But if you need a workplane OFF the origin plane, and do not want to use the origin plane to create it... you can create it off of some geometry in your part.
    Maybe post a screen shot or sketch of what you're trying to accomplish?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    *Expert Elite*
    12-17-2012 12:54 PM in reply to: cbenner
    cbenner wrote:
    I'm not sure exactly what you are trying to do, ...
    When creating iFeatures do not use the origin planes.  Can use part face (can be a dummy part - simple cube) - don't usually need a workplane, but if for some reason one is needed use dummy part face to create the plane.
    *Expert Elite*
    Curtis_Waguespack
    12-17-2012 01:02 PM in reply to: Mike686
    Hi Mike686,
    Typically when you're copying a part or feature you want to set them up to be as stable and self contained as possible. My advice for iFeatures is to choose origin planes or existing faces to use as sketch planes rather than creating work planes to sketch in. Otherwise the placement of the iFeature requires much more effort (basically you'd need to redefine the workplane again when placing it).
    So I'm not sure that I would advise creating a work plane not based on an origin plane for iFeatures any more than one that is created based on an origin plane.
    As others have suggested, you might share your specific case example for a better understanding of the challenge you're up against.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    Mike686
    12-17-2012 02:10 PM in reply to: Curtis_Waguespack
    hi guys,
    first what i wanted to do was created a ifeature of a slotted hole
    basicly its was for learning how to create an ifeatures
    so i went and grab my "mastering inventor 2012" book and start reading about ifeatures
    in the section "part and feature reuse" the part about ifeatures theres some tips for working with ifeatures
    and i saw this tips:
    "you should avoid the use of origin work planes,axes,and the origin center point for work features"...
    and JDMather, i was gonna do a dummy part to use for the creation of my feature...
    i saw the you tube video of ketiv technology and thats what the guy done in it..
    so created a part file with a dummy solid then create a sketch on one face, then do my feature base on that sketch would be  a good way to do it?
    *Expert Elite*
    PaulMunford
    12-17-2012 02:17 PM in reply to: Mike686
    'There can be only one'
    If you create iFeatures on the origin planes, when you place the iFeature it will place itself on the origin plane.
    So, just like in Jon's tutorial, create a 'dummy' part to create your iFeature on instead.
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
