• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    create reference line for angular dimension
    436 Views, 1 Replies
    08-17-2011 10:24 AM
    In the attached jpeg is a clip from my IDW showing part of a cross-section.  The o-ring groove shown in the cross-section has an angled wall, and I'd like to dimension it just the way it is dimensioned in the handbook (the dimension circled in red in the jpeg).
    What is the correct way to do this?
    (I can put a center mark on the radiused bottom corner, use that as a reference, and then make the center mark invisible.  But that offsets the vertical line from the wall, and makes the dimension less obvious to understand.)
    Please use plain text.
    Curtis_Waguespack
    Re: create reference line for angular dimension
    08-17-2011 10:50 AM in reply to: gnunesjr
    Hi gnunesjr,
    One way to do this is to:
    • select the view
    • create a new 2D sketch
    • project edges as needed
    • skectch a small "helper"  line
    • finish sketch
    • apply a dimension to the small sketch line and the model edge to ge the results you're after
    Selecting the view before creating the sketch is a key step.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
