• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    chriswillis5914
    create pdf faster
    216 Views, 9 Replies
    08-20-2012 09:18 AM
    Hello
    I have been looking at posts on automating pdf creation but have seen a lot with programming / VB involved but would like to avoid that if possible. I have also seen one's on batch processing but would like to do them as needed / completed.
    I am trying to somewhat automate the pdf creation process.  Having them save to a specific spot / folder and having them 'plot' the same view to the pdf would be very beneficial that way we dont have to select print, print  to pdf, print this view with these details, save to this folder location. etc.
    I look forward to your suggestions.
    Thank you
    Please use plain text.
    *Pro
    jletcher
    Re: create pdf faster
    08-20-2012 11:53 AM in reply to: chriswillis5914
    There is a snippit code for ilogic that will do what you ask. I wish I could post the link but I am having some issues. but you can do a search and it will pop up..
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    *Pro
    jletcher
    08-20-2012 11:55 AM in reply to: chriswillis5914
    Here go it to work
    http://forums.autodesk.com/t5/Autodesk-Inventor/Save-PDF-using-iLogic-and-name-after-revision-number...
    James Letcher
    *Expert Elite*
    mrattray
    08-20-2012 11:56 AM in reply to: jletcher
    Your going to have to use some sort of programing for this. Asking to automate something without coding is like saying "I want to create a drawing without having to draw anything".
    Mike (not Matt) Rattray
    Valued Mentor
    jdkriek
    08-20-2012 12:17 PM in reply to: mrattray
    That made me chuckle Matt. :smileylol:
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    chriswillis5914
    08-20-2012 12:22 PM in reply to: jletcher
    I am using inventor though, not ilogic. Can you clarify please
    *Expert Elite*
    mrattray
    08-20-2012 12:27 PM in reply to: chriswillis5914
    iLogic is a feature of Inventor. I suggest you look for some tutorials on the subject. I know AutoDesk University has some good instructional videos, and of course the standard Inventor tutorial package is sure to have some.
    Active Contributor
    andrewwhiteinc
    08-20-2012 03:35 PM in reply to: chriswillis5914
    The most you can automate without programming would be to install Bullzip PDF printer and configure it not to prompt. I use it for lots of programs to create PDFs that go into a specific folder.
    P. Andrew White,EIT
    Engineer-in-Training, Industrial Automation
    *Expert Elite*
    PaulMunford
    08-21-2012 04:55 AM in reply to: chriswillis5914
    Check out 'swift prints':
    http://cadsetterout.com/reviews/swift-prints-2-0-for-autodesk-inventor/
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    chriswillis5914
    08-21-2012 07:42 AM in reply to: PaulMunford
    bullzip seems to offer no benefit over adobe and starts out with the <smart title> which includes the entire file path in the name.  I watched a few tutorials online about it. am i missing something?
