Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
copy multiple objects
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to allow Inventor 2013 to copy multiple objects when executing the 'copy' command ? Similar to in AutoCAD where you can continue to copy objects in multiple instances instead of it terminated after a single copy ? Thanks
Re: copy multiple objects
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hold shift when selecting?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You haven't really given us enough information to be helpful, although John's reply might be exactly what you need. The answer will be different depending on what the objects are that you are trying to copy. Are you trying to copy components in an assembly? Sketch elements in a part sketch? Views in a drawing?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your response. To clarify, I am copying components in an assembly using the simple 'copy' command from the drop down menu which is available when right click on the component to copy, thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ctrl-click to multi-select, then copy.
Sam B
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
or
Ctrl click mutliple
or
Shift click first and last (all in between will be selected)
then click and drag one of the part icons into the graphics window and all will be copied.
