• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    copy multiple objects
    160 Views, 5 Replies
    01-23-2013 04:17 AM
    Is there a way to allow Inventor 2013 to copy multiple objects when executing the 'copy' command ? Similar to in AutoCAD where you can continue to copy objects in multiple instances instead of it terminated after a single copy ? Thanks
    Please use plain text.
    Distinguished Mentor
    Re: copy multiple objects
    01-23-2013 05:31 AM in reply to: Anthony
    Hold shift when selecting?
    John Retzlaff
    *Pro
    01-23-2013 05:46 AM in reply to: Anthony
    You haven't really given us enough information to be helpful, although John's reply might be exactly what you need.  The answer will be different depending on what the objects are that you are trying to copy.  Are you trying to copy components in an assembly?  Sketch elements in a part sketch?  Views in a drawing?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Anthony
    01-23-2013 05:51 AM in reply to: sbixler
    Thank you for your response. To clarify, I am copying components in an assembly using the simple 'copy' command from the drop down menu which is available when right click on the component to copy, thanks
    *Pro
    01-23-2013 08:31 AM in reply to: Anthony
    Ctrl-click to multi-select, then copy.
    Sam B
    *Expert Elite*
    01-23-2013 08:51 AM in reply to: sbixler
    or
    Ctrl click mutliple
    or
    Shift click first and last (all in between will be selected)
    then click and drag one of the part icons into the graphics window and all will be copied.
