• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    convert to a sheet metal part
    256 Views, 4 Replies
    11-03-2012 03:50 AM
    The part posted with this question is made with Inventor 2013.I would prefer to make this part with the Sheet Metal tools .Please how would this be made with sheet metal tools and how do i flatten this piece?
    Best Regards
    Harold Kennedy
    Please use plain text.
    *Expert Elite*
    Re: convert to a sheet metal part
    11-03-2012 05:24 AM in reply to: harold_kennedy
    You could simply Convert to Sheet Metal (see attached).  (done in student version - so examine and then delete)
    or
    you only need three lines 100, 30, 70 that's it - an open profile and use the Contoured Flange tool to create the bracket and then use the Cut just like you did Extrude.
    11-04-2012 12:23 AM in reply to: harold_kennedy
    Mr J.D Mather
    Thanks for guidance
    I attached a file using your recommendations
    Is this correct
    Harold
    *Expert Elite*
    mrattray
    11-05-2012 04:25 AM in reply to: harold_kennedy
    You don't have to model bend radii. If you draw your contour flange profile to sharp corners Inventor will automatically draw bends in based on the bend radius specified in your sheetmetal defaults.
    Mike (not Matt) Rattray
    *Expert Elite*
    11-05-2012 04:39 AM in reply to: harold_kennedy
    These parts are not the same.
    You used 10mm external bend radius on both bends on first part
    and 10mm on one external and on internal bend on second part.
    As I initially wrote - you need only three lines in that first sketch - that's it.  Nothing more.
