Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
convert to a sheet metal part
- Highlight
- Email to a Friend
The part posted with this question is made with Inventor 2013.I would prefer to make this part with the Sheet Metal tools .Please how would this be made with sheet metal tools and how do i flatten this piece?
Best Regards
Harold Kennedy
Re: convert to a sheet metal part
- Highlight
- Email to a Friend
You could simply Convert to Sheet Metal (see attached). (done in student version - so examine and then delete)
or
you only need three lines 100, 30, 70 that's it - an open profile and use the Contoured Flange tool to create the bracket and then use the Cut just like you did Extrude.
- Highlight
- Email to a Friend
Mr J.D Mather
Thanks for guidance
I attached a file using your recommendations
Is this correct
Harold
- Highlight
- Email to a Friend
You don't have to model bend radii. If you draw your contour flange profile to sharp corners Inventor will automatically draw bends in based on the bend radius specified in your sheetmetal defaults.
- Highlight
- Email to a Friend
These parts are not the same.
You used 10mm external bend radius on both bends on first part
and 10mm on one external and on internal bend on second part.
As I initially wrote - you need only three lines in that first sketch - that's it. Nothing more.
