Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
convert Inventorfi le to stl
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've converted a Inventormodel with the exportfunktion in a stl-file.
This morning I get the Model produced with a SLS (Laser-Synther) and it was ca 2,54x the size it should have...
So they said the lenght must have been converted to inch...
Then I convert a file to stl and then to a step it seems that it becomes in every conversation 2,5x the size....
So what's the matter?
Please excuse my bad style (I'm from Germany).
I hope sombody can help me.
With friendly regards,
Holger
Re: convert Inventorfi le to stl
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi, can i ask if you had set your units to metric mm, or is it set to imperial inches?
via options in tools, document settings
if it was imperial & you need to swap over to metric, then you will have to edit the dimensions and type mm after the value to make it the correct size.
Inventor 2014 Pro on Windows 7, 64bit
(please give Kudos or Tag as Solved if your issue is resolved)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi sholger,
I think you can click the Options button when saving out the STL file and set the *.stl units to match your document units.
Note that this has changed over the years, so if you don't see the option it might be due to the version of Inventor you're using (I seem to recall a bug with this in earlier versions).
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The Inventorfiles (ipt) are corekt
So are the drawings / sketches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have reimported the stl file to check:
it says, that the file is metric...
| Quelldatei: | ...Prototyp\Lok mini 50.stl | ||
| Translator-Typ: | STL | Sendendes System: | |
| Autor: | Translationszeit: | 00:00:00 |
| Optionen | |
| Importtyp: | Nicht zutreffend |
| Zu importierende Objekttypen: | Netze |
| In Reparaturumgebung importieren: | Unknown |
| Baugruppe als einzelnes Bauteil importieren: | Nicht zutreffend |
| Flächen erstellen als: | Nicht zutreffend |
| Mehrere Volumenkörperbauteile als Baugruppe importieren: | Unknown |
| Einheiten: | Millimeter |
| Bauteile beim Laden überprüfen: | Unknown |
| Autom. heften: | Unknown |
| Erweiterte Korrektur aktivieren: | Unknown |
| Farbfolge Rot/Grün/Blau: | RGB |
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi sholger,
To clarify, I think you'll need to re-save the file as an STL and use the Options button to ensure the units are set correctly:
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Which program did you use?
Or how do you get the dialog save copy as?
I'm confused...
Greetings
Holger
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi sholger,
From within Autodesk Inventor
Select ![]()
Save As
Save Copy As, then use the Options button shown previously.
Also see this link:
look for the STL File Save As Options
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It has been reported here many time (a search might turn up previous threads) that the Options>Units must be set on saving stl files.
Unfortunately it has also been reported here (a search might turn up previous threads) that Inventor Import of stl cannot be relied on as a check of size as Inventor does not import the files correct units in some cases.
There are other software programs that can be used to verify the geometry size.
The best bet is to indicate to the person who will run the job what the bounding box size for the part should be.
