• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    convert Inventorfile to stl
    166 Views, 8 Replies
    11-30-2012 07:16 AM
    I've converted a Inventormodel with the exportfunktion in a stl-file.
    This morning I get the Model produced with a SLS (Laser-Synther) and it was ca 2,54x the size it should have...
    So they said the lenght must have been converted to inch...
    Then I convert a file to stl and then to a step it seems that it becomes in every conversation 2,5x the size....
    So what's the matter?
    Please excuse my bad style (I'm from Germany).
    I hope sombody can help me.
    With friendly regards,
    Holger
    Please use plain text.
    Valued Mentor
    Re: convert Inventorfile to stl
    11-30-2012 07:54 AM in reply to: sholger
    hi, can i ask if you had set your units to metric mm, or is it set to imperial inches?
    via options in tools, document settings
    if it was imperial & you need to swap over to metric, then you will have to edit the dimensions and type mm after the value to make it the correct size.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Curtis_Waguespack
    11-30-2012 08:13 AM in reply to: sholger
    Hi sholger,
    I think you can click the Options button when saving out the STL file and set the *.stl units to match your document units.
    Note that this has changed over the years, so if you don't see the option it might be due to the version of Inventor you're using (I seem to recall a bug with this in earlier versions).
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    11-30-2012 01:40 PM in reply to: Mark_Wigan
    The Inventorfiles (ipt) are corekt
    So are the drawings / sketches
    Member
    11-30-2012 01:44 PM in reply to: Curtis_Waguespack
    I have reimported the stl file to check:
    it says, that the file is metric...
    Quelldatei:...Prototyp\Lok mini 50.stl
    Translator-Typ:STLSendendes System:
    Autor: Translationszeit:00:00:00
    Optionen
    Importtyp:Nicht zutreffend
    Zu importierende Objekttypen:Netze
    In Reparaturumgebung importieren:Unknown
    Baugruppe als einzelnes Bauteil importieren:Nicht zutreffend
    Flächen erstellen als:Nicht zutreffend
    Mehrere Volumenkörperbauteile als Baugruppe importieren:Unknown
    Einheiten:Millimeter
    Bauteile beim Laden überprüfen:Unknown
    Autom. heften:Unknown
    Erweiterte Korrektur aktivieren:Unknown
    Farbfolge Rot/Grün/Blau:RGB
    Curtis_Waguespack
    11-30-2012 02:11 PM in reply to: sholger
    Hi sholger,
    To clarify, I think you'll need to re-save the file as an STL and use the Options button to ensure the units are set correctly:
    I hope this helps.
    Curtis
    Member
    11-30-2012 02:16 PM in reply to: Curtis_Waguespack
    Which program did you use?
    Or how do you get the dialog save copy as?
    I'm confused...
    Greetings
    Holger
    Curtis_Waguespack
    11-30-2012 02:21 PM in reply to: sholger
    Hi sholger,
    From within Autodesk Inventor
    Select Save AsSave Copy As, then use the Options button shown previously.
    Also see this link:
    Export parts and more
    look for the STL File Save As Options
    I hope this helps.
    Curtis
    11-30-2012 02:26 PM in reply to: sholger
    It has been reported here many time (a search might turn up previous threads) that the Options>Units must be set on saving stl files.
    Unfortunately it has also been reported here (a search might turn up previous threads) that Inventor Import of stl cannot be relied on as a check of size as Inventor does not import the files correct units in some cases.
    There are other software programs that can be used to verify the geometry size.
    The best bet is to indicate to the person who will run the job what the bounding box size for the part should be.
