• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    mokqinglin21
    convert 2D DXF to 3D inventor model 2012
    269 Views, 6 Replies
    02-04-2013 06:49 PM
    hi im wondering if it is possible to convert a 2D dxf to 3D in 2012 inventor? I couldnt do after I downloaded the updates for 2D to 3D conversion. I wonder if such a conversion is only available for 2D DWG files
    Please use plain text.
    *Expert Elite*
    blair
    Re: convert 2D DXF to 3D inventor model 2012
    02-04-2013 08:14 PM in reply to: mokqinglin21
    You should be able to open the DXF file with Autocad that ships with Inventor and save to DWG
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Active Member
    mokqinglin21
    02-04-2013 08:24 PM in reply to: blair
    hi,
    I have no idea why I couldnt convert the 2D to 3D even though I have downloaded the 2D to 3D tool and tried to follow the tutorial online.
    Can someone help me to convert this file?
    *Expert Elite*
    blair
    02-04-2013 08:49 PM in reply to: mokqinglin21
    A lot of the utilites in Inventor are looking for a specific file format, such as "Place Component". It won't run the conversion program, this is only done with the File-Open command.
    You need to open this file in Autocad, not Inventor and do the conversion there and do a Save-As to DWG in Autocad. I am at home and need my install media to configure Autocad for a couple of updates before I can open Autocad
    Win7-64
    *Expert Elite*
    02-05-2013 04:55 AM in reply to: mokqinglin21
    I had no trouble opening directly in Inventor and create the 3D solid parts.
    I didn't need AutoCAD.
    How much Inventor training have you had?
    Active Member
    mokqinglin21
    02-05-2013 06:21 AM in reply to: JDMather
    I have never tried converting 2D drawings from outsource companies to 3D autodesk inventor
    I followed the steps in
    http://cadsetterout.com/resources/autocad-inventor-2d-to-3d-conversion/
    I just dont understand why I couldnt select the drawing for base and projected view.
    May I know how did you do it?
    *Expert Elite*
    02-05-2013 09:39 AM in reply to: mokqinglin21
    I have never used any "2D to 3D converter".
    Pretty simple geometry to create myself.
