• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    constraint question
    29 Views, 4 Replies
    12-10-2002 12:13 AM
    I am drawing an assembly of a spring loaded ball plunger.
    When I insert the ball into the housing, what type of constraint should I use to ensure the ball protrudes .048"
    from the housing.
    Please use plain text.
    *Dotson, Sean
    Re: constraint question
    12-10-2002 12:20 AM in reply to: koehler
    You'll need to use some workplanes on the ball and
    the socket.  Then use mate-mate on the ball and socket's workplanes.
    (You can even get fancy then make them adaptive to have the ball retract when
    necessary <g>)
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    Check the Inventor
    FAQ for most common questions
    href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
    I
    When I insert the
    protrudes .048"
    from the housing.
    Re:
    12-10-2002 02:36 AM in reply to: koehler
    OK. Got it. One more constraint question:
    How do I constain 4 slotted holes to 4 shafts and centered on the slotted hole?
    Thanks Bill
    *Dotson, Sean
    Re:
    12-10-2002 02:44 AM in reply to: koehler
    Make two workplanes bisecting each slot in each
    direction.  Now put a axis through the planes (it's now perp to your
    surface).  Now mate-mate the axis to the shafts.
    Sean Dotson, PE
    Check the Inventor
    OK.
    Bill
    Re:
    12-10-2002 02:55 AM in reply to: koehler
    When I draw the slot I usually have some type of point in the center of the sketch I extruded. A workpoint or the end of a construction line. After I extrude the slot I turn the sketch visibility on and create a work axis by selecting the sketch plane and then my center of the slot (the 2D sketch point). I then turn the sketch visibility off. - Rich Thomas
