Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
constraint issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
While creating an assembly I will mate components together to a grounded component and the assembled parts are allowed to be moved and or rotated.
To get them back into position I need to click re-build.
Previously once you mated parts together I was unable to move or rotate them (they would become anchored)
Have I in-advertently changes a setting? And if so how do I get it back?
Thanks in advance
William K. Skidmore
White Conveyors Inc.
Re: constraint issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you using the Move command to move them, or are you just dragging them? The behavior you describe is normal behavior if you use Move to drag a component. However, it is not normal behavior for simply dragging a fully constrained component.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi! It sounds like you might have turn on Defer Update in the assembly. Please go to Tools -> Application Options -> Assembly -> uncheck Defer Update.
If it does not help, please post the files you are having trouble with here or send them to me.
Thanks!
Principal SQA Engineer, Inventor
Manufacturing Group
