• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    keith.skidmore
    Accepted Solution
    constraint issue
    103 Views, 2 Replies
    05-04-2012 07:11 AM
    Hello
    While creating an assembly I will mate components together to a grounded component and the assembled parts are allowed to be moved and or rotated.
    To get them back into position I need to click re-build.
    Previously once you mated parts together I was unable to move or rotate them (they would become anchored)
    Have I in-advertently changes a setting? And if so how do I get it back?
    Thanks in advance
    William K. Skidmore
    White Conveyors Inc.
    Please use plain text.
    *Expert Elite*
    Re: constraint issue
    05-04-2012 08:10 AM in reply to: keith.skidmore
    Are you using the Move command to move them, or are you just dragging them?  The behavior you describe is normal behavior if you use Move to drag a component.  However, it is not normal behavior for simply dragging a fully constrained component.
    Employee
    05-04-2012 01:06 PM in reply to: keith.skidmore
    Hi! It sounds like you might have turn on Defer Update in the assembly. Please go to Tools -> Application Options -> Assembly -> uncheck Defer Update.
    If it does not help, please post the files you are having trouble with here or send them to me.
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
    Autodesk, Inc.
