Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
connector + hose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there another way of doing this other then using the pipe and run tools.There are 6 x 10mm connectors.I want to run 10mm plastic tube from the bottom 3 connectors up to the top 3 connectors.Please how can this be done other then using pipe and tube tools?
Regards
Terry
By the way is this simple if using the pipe and run tools?
Re: connector + hose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is this only achievable by using the Tube & Pipe tools?
Terry
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you don't want to use Routed Systems then simple start a new part in the context of the assembly.
Project Geometry a connection point (like a circle or similar) from each connector.
This will make the new part adaptive to the position of the connectors.
Create 2D or 3D sketch for your tube run and Sweep.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks...i`m new to what you suggest...could you give an example of how you would do this or could you add the hoses to the conectors i attached in my first post...
Is there any difference between the way you explained to do this and the Routed system.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Terry__Close wrote:Is there any difference between the way you explained to do this and the Routed system.
This is basically what Routed Systems does - but it has tools that automate the process so that it is fewer steps.
The attached was done in student version - so keep separate from your data and delete after examination of technique.
1. Turn on or create connection point in Connectors (I used origin Center Point and logical axis).
2. Create New Part in assembly. (set to constrain to connector part)
3. I like to then exit part and add second constraint to axis of new part and connector.
4. Edit the part and start new sketch and Project Geometry for the tubing profile.
5. Start a 3D sketch and Include Geometry the connection points at both ends of tube.
6. Create lines for straight sections of tubing (if all will be straight I might do these in 2D sketches instead, depending on how tightly I need to control the location).
7. Connect the 2D lines (in my simple case attached) with spline, including as many points in space as needed to control the path (if this is bent tubing I do slightly different with Bends between straight line sections). Add tangencies to lines at start and end.
8. If you need additional point to the spline you can add them. You can use the 3D Move/Rotate tool to move points as needed.
9. Sweep the profile.
Repeat as needed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks JD
