• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    configuration file for wiring (.cfg file)
    286 Views, 3 Replies
    07-05-2005 02:01 AM
    Dear all,
    I am struggling in configuration file (.cfg).
    how can i create new configuration file.while importing wire list configuration file we have to bring from some location.after
    bringing cfg.it is supporting .it is giving error.i am mentioning that error below.
    "There was an error parsing the configuration file
    error 1 warning 0 "
    I need following clarifications ,
    1.first of all ,i need clear idea about .cfg.so,that I need install any .cfg software.or how can i enter wire parameters?
    2.is it support excel or notepad or word or some other.please
    tell me guidelines with proper examples.
    3.Actually,what i did in inventor harness assy.i have stored wire parameters in excel.i tried to convert .cfg file .
    but,it is not taking (i used tab delimited txt fille also).i couldn,t get yet.
    if anyone gives prefect idea with examples.i am appreciated that guys.it will help lot for me.
    I am expecting your reply as early as poosible.
    G.Manikandan
    Please use plain text.
    *Sami KOZONO \(Autodesk\)
    Re: configuration file for wiring (.cfg file)
    07-05-2005 06:05 PM in reply to: G.Manikandan
    G.Manikandan
    There are some sample CFG files you can refer. They can be found under
    C:\Program Files\Autodesk\Inventor Professional 10\Cable &
    Harness\Samples\Wire List Import
    CFG files for wire import are either comma or semi-colon delimited ASCII
    text files.
    You can edit them with Notepad, Word, or Excel but make sure the output is
    properly
    formatted & encoded.
    -Sami KOZONO
    Inventor Modeling QA
    *Wei Li \(Autodesk\)
    07-05-2005 07:20 PM in reply to: G.Manikandan
    Answers to your questions:
    1. you don't need to install any software for the CFG file for wire import.
    JUST use notepad to edit it. (FYI, the CFG file used for report generator is
    in different format. you should use report generator's "edit configuration
    file" dialog to edit it)
    2. as I said above, please just use notepad or other plain text editor
    3. you cannot directly convert the excel file to cfg. CFG file for wire
    import has its own format. You can go to the help file for details. (select
    "Import Wire List" from the panel, click the help icon at the bottom-left
    corner, click "Concept". At the bottom, there are two links: "Learn about
    formatting the wire list" and "Learn about creating a wire list". They
    explain the format of cfg and csv respectively)
    We also have sample files under "Inventor Professional 10\Cable &
    Harness\Samples\Wire List Import\". Please notice that they are either comma
    or semi-colon delimited. You should check your regional settings (list
    separator) to choose the correct one.
    Wei Li (AIPQA)
    дÈëÏûÏ¢ÐÂÎÅ:4892483@discussion.autodesk.com...
    Dear all,
    below.
    error 1 warning 0 "
    yet.
    G.Manikandan
    New Member
    11-21-2012 07:47 PM in reply to: *Wei Li \(Autodesk\)
    Is there a place where these Sample files are Mirrored somewhere for download?  Somewhere down the line my Sample .cfg files have gone missing and annot export my Harness details.  Any suggestions?
