• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    coincidence point in 3D sketch
    205 Views, 7 Replies
    12-15-2012 11:45 AM
    I want to concide two points of two different lines.These two lines have been created in two different workplanes with 2D sketch.
    Please use plain text.
    *Expert Elite*
    blair
    Re: coincidence point in 3D sketch
    12-15-2012 11:59 AM in reply to: mech5328
    The only way I think this could be done, would be to project the geometry from the first sketch onto the second sketch that you are working on to be able to find the coincedence.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    *Expert Elite*
    12-15-2012 05:19 PM in reply to: mech5328
    Attach the ipt file here.
    Active Member
    12-16-2012 03:24 AM in reply to: JDMather
    I want to coincide the midpoint of the edge of the rectangle with the edge of the spline curve.The rectangle is created in xy plane and the spline in xz plane.
    *Expert Elite*
    12-16-2012 03:36 AM in reply to: mech5328
    Something like this?
    (see attached)
    Active Member
    12-16-2012 03:48 AM in reply to: JDMather
    Yes.What's the way to do it?
    *Expert Elite*
    12-16-2012 12:28 PM in reply to: mech5328
    Project Geometry.
    I recommend you set aside your project for a few days while you do these Tutorials
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126
    then these
    http://inventortrenches.blogspot.com/p/inventor-tutorials.html
    and after this one
    http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    come back and ask more questions when you have more trouble.
    Active Member
    12-17-2012 02:27 AM in reply to: JDMather
    Ok
    Thank you very much.
