Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
coil grease groove
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to see what kind of a groove I would get if I machine it using a 1 1/4" rotating form tool. We will be cutting these grooves in a CNC milling machine with the tool in the spindle. We have taken a 1" round bar, cut a slot in the end of it and inserted a 3/8" tool bit with a 3/16" radius on it. The tip of the tool will be spinning at a 5/8" radius. (1 1/4" bar).
The bushing will have 2 lengthwise grooves down it at 180°. 2 full rotations each. If I coil an 1 1/4" diameter down the length of the part in inventor, I am not getting a true representation of what the groove will look like, because it is not taking the form of the tool into consideration.
Any help is appreciated.
Windows 7 professional
Service Pack 1
HPZ210 workstation
Xeon CPU E31245 @ 3.30 GHz
16GB RAM
64-bit
Invenor 2012, 64 bit
Build 190, 2012 SP1
Re: coil grease groove
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you post a picture of the machined item
Win7-64
EVGA X58 - Classified, iCore7 990 24Gb Trip-Channel
480Gb (2 x 240Gb SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-590 Classified - 301.42
SpacePilot 3.15.3 / 6.15.3 / 3.12
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is the orientation of the tool in the actual manufacturing process (your tool is not perpendicular to the start of the helix path. You might need to create a helical path, workplane perpendicular to the start and then sketch on the workplane.
Coil always gives an incorrect result unless the start profile really isn't perp to path. Most don't even realize the geometry isn't correct.
Autodesk Inventor Certified Professional
Inventor Professional 2012 Edu 32-bit
Still waiting for -Draft option on any Rib feature. -Properties Painter.
Still wondering why Edit Form is above Edit Feature on RMB?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do not have a picture of a finished part. We are creating this into an existing bushing to try and flush contaminates out while the pump is running. These bushings are submerged in water and the shaft that goes through them is rotating counterclockwise.
Mr Mather, the tool will be a high speed tool bit welded perpendicular to the bottom of a 1" shaft. The tool bit will stick out beyond the edge of the 1" shaft 1/8", thus the 5/8" radius. The tool bit will have a 3/32" radius on the cutting edge.
The 1" shaft will be rotating at a high RPM while the spindle moves vertically down through the part (Z axis). As the spindle moves down through the part, the X and Y axis of the machine will interpolate around the center of the bushing.
The part I sent in the original message would only show what a cut would look like if my tool had no thickness. My tool will be 3/16" wide with a 3/32 radius on the end of it. I'm sure it will turn out fine, I was just trying to get a true representation of the groove itself. I'm not sure I understand what you mean when you say to create a plane perpendicular to the coil itself.
We could cut this in our lathe and the I could get a true representation of that cut in Inventor, however, we have decided to cut these in a machining center for other reasons.
Service Pack 1
HPZ210 workstation
16GB RAM
64-bit
Build 190, 2012 SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
tj2057 wrote:I'm not sure I understand what you mean when you say to create a plane perpendicular to the coil itself.
I will post example when I get a chance.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would something like this get you the geometry you are looking for. This is just one cut to get the 2D profile of the cuttier perpendicular to the cut path.
Corey Parks
IV2011 Factory Design Suite Advanced 64bit - sp2
Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
Windows 7 64 bit- Synergis Adept document management software
12gb RAM --- Nvidia Quadro 4000 2gb
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having a hard time explaining this.
I have attached another file that hopefully shows how I am trying to machine this part. The red part represents what the tool looks like. The red will be rotating from the spindle and will move vertically down through the part. While it is moving vertically, the x and y axis of the machine will move in sync with each other to cut the tool path on all three axis at once. I was able to make a representation of it in GibbsCam. I found that the thickness of the tool nose (.080) does not make a difference past a certain amount. i.e, if the tool was .030 wide or .060 wide, it makes no difference in the cut. Now, if I were to use a tool 1/4" wide, the path the tool take out would be quite a bit larger. This is because of the relationship between the helix and the fact that the tool is not parallel with the helix path.
Service Pack 1
HPZ210 workstation
16GB RAM
64-bit
Build 190, 2012 SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is what we mean by perpendicular. I did this coil cut on the outside.
You angled sketch plane would only work if your cutter was angled. Your cutter is perpendicular, so your sketch plane for your cut profile must be perpendicular as well.
Win7-64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perhaps this thread might give you some insight:
It sounds like a similar problem. I realize it is not exactly the same thing, but it may prove useful anyway.
Please click "Accept as Solution" if this response answers your question.
IV2012 Professional SP1, Build 190; Vanilla Vault 2012, Update 1
Windows 7 Pro 64-bit SP1; Intel Xeon Duo @2.40 GHz, 6 GB RAM,
NVIDIA Quadro 2000, 1024 MB GDDR5
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks cwhetten and everyone else.
attached.
I think I have it solved. I drew a representaion of the tool. I created a workplane at the end of the coil, projected the elipse from the tool and did a sweep cut.
Roll the EOP down.
Service Pack 1
HPZ210 workstation
16GB RAM
64-bit
Build 190, 2012 SP1
