Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
circular pattern
Options
- Highlight
- Email to a Friend
205 Views, 2 Replies
01-19-2013 04:26 AM
On the circular pattern i used 10 increments @ 300 degrees....why does the 10th increment not line up at the 10th position...have i got the maths wrong?
Please see attached
Simon
Re: circular pattern
Options
- Highlight
- Email to a Friend
01-19-2013 07:16 AM in reply to:
simon_toaldo
Hi simon_toaldo,
You'll need to adjust for the angle of the extrusion, to consider the pattern start point. Here I've created a driven dimension called d67, which has a value of 1.59 degrees and then I subtracted that from the 300 degrees in the pattern.
I hope this helps.
Curtis
Options
- Highlight
- Email to a Friend
01-21-2013 04:22 AM in reply to:
simon_toaldo
Thanks Curtis
