circular pattern
circular pattern
circular pattern
On the circular pattern i used 10 increments @ 300 degrees....why does the 10th increment not line up at the 10th position...have i got the maths wrong?
Please see attached
Simon
Curtis_W
Hi  simon_toaldo,
You'll need to adjust for the angle of the extrusion, to consider the pattern start point. Here I've created a driven dimension called d67, which has a value of 1.59 degrees and then I subtracted that from the 300 degrees in the pattern.
I hope this helps.
Curtis
Thanks Curtis
