• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    dash1982
    Accepted Solution
    cant open inventor 2011 undo folder message
    2073 Views, 14 Replies
    02-28-2011 06:54 AM
    when i try to open my 2011 inventor program which ive been running for months now i get an error message. and the program refuses to open. "Error in Inventor Undo Folder: Please Make Correction" any ways to fix this so i can get back to work. and i should add that i am not a computer genius im a furniture designer. please help me out here
    Please use plain text.
    *Pro
    Re: cant open inventor 2011 undo folder message
    02-28-2011 07:01 AM in reply to: dash1982
    Let's start with your system specifications See this for what is needed:
    http://teknigroup.com/support/Inventor/Howto.html
    Something else to check (if you can get this far. Open Inventor, go to tools >> Application Options without opening a file:
    What do you see here under the general tab?
    ____________________________________________________________
    Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert
    Autodesk Silver Manufacturing Partner
    Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
    XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
    Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
    Member
    dash1982
    02-28-2011 07:05 AM in reply to: Dennis_Jeffrey
    like i said ive been running this program since it came out with no problems. and nothing has changed on my computer as far as system requirements go
    *Pro
    02-28-2011 07:08 AM in reply to: dash1982
    Good luck finding an answer without providing information that is needed.
    Employee
    02-28-2011 10:02 AM in reply to: dash1982
    I did a search in the source code for Inventor. You should see a dialog, not just a Message box.
    The Dialog should give additional information to fix the problem:
    Current Undo Folder:
    Undo Folder Status:
    In order to help you with this issue, it would be best if you could post a screenshot of this dialog here.
    regards,
    Gerald
    Gerald Hochenauer(gerald.hochenauer@autodesk.com)
    Inventor Principal Software Engineer
    Manufacturing Group
    Autodesk, Inc.
    Member
    dash1982
    02-28-2011 10:09 AM in reply to: Hochenauer
    No worries guy I fixed it myself. Thanks for tryi g to help.
    **Master
    02-28-2011 10:10 AM in reply to: dash1982
    would mind providing the solution, for the next person that finds your thread while searching for the same issue.
    thanks
    Employee
    02-28-2011 10:11 AM in reply to: dash1982
    Please mark the thread as fixed then - no use spending time if there is no further need for help.
    Thanks!
    03-21-2011 03:57 AM in reply to: BMiller63
    Yes Dash1982,
    I agree with this question, can you post the solution because I got the same error on a fresh installation of AutoCADInventor and I have  no idea how to solve this problem. I'd like to prevent that our users get this message
    If possible I would like to change the path to a location where All Users have acces (for instance d:\Undo) but where can I configure this setting?
    Best regards,
    New Member
    jane.hokans
    09-29-2011 09:43 AM in reply to: dash1982
    I am having this problem in our school district.  I believe it is related to roaming profiles.  I would like to know how to set the path for the undo folder to a place everyone will have access to.  Can anyone help?
