• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    border made for A4 sheet,now i Need for A3,A2 sheet
    243 Views, 3 Replies
    12-03-2012 05:20 AM
    i made new borde for A4 sheet and now when i am shifting to A3 Or A1, border remains same as A4 sheet size only changing.kindly reffer the  image attached.Kindly solve
    Please use plain text.
    *Pro
    jletcher
    Re: border made for A4 sheet,now i Need for A3,A2 sheet
    12-03-2012 07:04 AM in reply to: viveksriramr
    You would have to make a border for each size. Then if you want them to change automaticaly you will have to write some ilogic code to do this.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    12-03-2012 08:08 AM in reply to: viveksriramr
    If you don't need for it to be fully automatic - the solution could be as simple as double clicking on the correct boarder in the Drawing Resources>Borders to change after-the-fact of creating or editing the sheet.
    *Pro
    12-03-2012 06:03 PM in reply to: viveksriramr
    In your border definition, you can dimension the border from the sheet corners.  This will allow it to stretch with the sheet size, as long as you don't mind
    Since we stick pretty close to the ASME standards, though, which have differing border widths for different sheet sizes, we are not able to take advantage of this.  We have five different border definitions.
