• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    blank ribbon & no text in Inventor screen
    1581 Views, 11 Replies
    01-29-2011 05:55 AM
    After 2nd "clean install" we have no ribbon graphics or menu text on an otherwise recognizable Inventor screen.  This is true with the standard user as well as the Admin.  Phone consultation with our Autodesk vendor has not produced anything.  Do you have any ideas on this?
    Please use plain text.
    *Pro
    Re: blank ribbon & no text in Inventor screen
    01-29-2011 06:41 AM in reply to: PENengr
    What are the specs on your system - especially graphics? See this link for information that is needed to help.
    http://teknigroup.com/support/Inventor/Howto.html
    Standard Installation - Specific Instructions:
    http://teknigroup.com/support/InstallAdsksoftware.html
    ____________________________________________________________
    Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert
    Autodesk Silver Manufacturing Partner
    Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
    XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
    Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
    *Pro
    01-29-2011 06:46 AM in reply to: PENengr
    Just a thought...
    Post a screen shot if possible. Does it lool like this??
    Active Contributor
    01-31-2011 06:01 AM in reply to: Dennis_Jeffrey
    Attached is a screen shot.
    Computer specs:
    Intel Core2 Quad
    Q9450 @2.66GHz
    2.66 GHz, 3.25 GB RAM
    video card = NVIDIA Quadro FX 3700
    Thanks, Greg
    *Pro
    01-31-2011 10:01 PM in reply to: PENengr
    Have you updated your graphics card driver?
    Have you changed fonts in Application Options >> General tab? (Should be Tahoma 8 Pt by default)
    Have you deleted any fonts?
    Member
    02-17-2011 11:54 AM in reply to: PENengr
    I just got done working with one of my users that has this same issue. I found that if you delete the file C:\Documents and Settings\USER_LOGIN\Application Data\Autodesk\Autodesk Inventor 2010\RibbonUICustomization.xml. that the ribbon has the text back. Deleting the file is only a check and a work-around. The file "RibbonUICustomization.xml" is recreated on exit from the application. To resolve the issue I had to recreate the user's Windows profile, it has solved this issue on our system. I guess there is some corruption between the user's profile (registry SID) and the application. Don't know, just know what has worked for me.
    Active Member
    justmanson
    02-18-2011 12:04 PM in reply to: PENengr
    I'm having the same issue.  Tried the above fix, but still no dice.
    I am running the latest graphic drivers for my radeon 1650
    i have not removed any fonts or anything else.
    I have cleared the Ribbon file from all of the profile users and from the registry.
    Any other suggestions?
    Distinguished Mentor
    02-18-2011 01:34 PM in reply to: justmanson
    Without re-reading the entire thread, have you tried switching from the Ribbon to the Classic UI and back? Maybe close IV in between UI's.
    Active Member
    justmanson
    02-22-2011 09:02 AM in reply to: PENengr
    no i haven't tried that.  I'm not sure where to even go to do that... since i can't see anything.
    **Master
    02-22-2011 09:10 AM in reply to: justmanson
    Applicaton Options > Colors tab > Interface Style
