Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
bend relief missing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The attached part is mising the bend relief. I expect to see a 3 sided cutout in the seam.
Why won't it create it?
Thanks for checking.
Re: bend relief missing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your sketches aren't constrained.
http://home.pct.edu/~jmather/skillsusa%20universit
Looks like you are doing too much work - should be able to create with half (or fewer) the number of features.
And the holes on one end have strange sizes (when measured in inches or millimeters.
I don't understand what bend relief is missing?
Can you post a screen shot with circle around area of question?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The bend relief should be approx. the geometry that is drawn with the red lines on the image "flatpattern".
The circled geometry on image "bend relief" should appear on the flat pattern when you flatten it.
If you think the part can be more efficient, feel free to modify it for my reference.
Thank you !
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is this what you are after?
What about those holes (Cut 7) before I post an alternate solution - what size are they supposed to be?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the process of remodeling your part I noticed that you used a Fixed constraint in Sketch1.
I have not used a Fixed constraint since leaving MDT (sometime in 2002).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You found it! ( the bend relief)
The holes should be .53"
What's wrong w/using a fixed constraint? I do it all the time.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
invent.ind wrote:You found it! ( the bend relief)
In the part you attached the holes on the one side are not .53"
I suspect you have been doing a lot of things incorrectly and more work than you need to do.
Forget the Fixed Constraint - everytime you are tempted to use it - attach your file here and ask for better way.
Here is a simplfied (fully constrained) example of your part, but I still need to do some work to get the corners you are after.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
...check this one too.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think I can handle the corners.
I did do some extra work, after looking at your version.
