• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    JimSteinmeyer
    Accepted Solution
    bend lines in export face
    93 Views, 4 Replies
    02-08-2012 11:29 AM
    When I use "export face as" to create a DXF file for our lazer table I loose the bend lines in the DXF. Is there a way to retain the lines in order to have the lazer scribe the bend lines for us?
    Thank you
    Jim
    Inventor 2012 SP1
    Vault 2012- plain vanilla version
    HP G71 notebook
    celeron cpu w\ 4gb RAM and 64 bit system
    Win 7 home premium
    Ya, my boss has me running my personal machine at work.
    Distinguished Mentor
    MariaManuela
    Re: bend lines in export face
    02-09-2012 02:17 AM in reply to: JimSteinmeyer
    Rigth-click over the Flat Pattern browser icon and choose Save Copy As (SAT; DXF or DWG)
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    JimSteinmeyer
    02-09-2012 08:17 AM in reply to: MariaManuela
    Maria,
    When I exportede the file this way it not only gave me the bend lines but also included the lines on both sides of the bend and placed points at all intersections which would cause problems in the torch pattern. I did save it as a 2004 dxf. does it make a difference which year of dxf I use? I am usnig Inventor 2012.
    Thank you
    Jim
    Jim
    Inventor 2012 SP1
    HP G71 notebook
    Win 7 home premium
    MariaManuela
    02-09-2012 08:58 AM in reply to: JimSteinmeyer
    That lines on both sides of the bend are the Tangent Lines.
    During Save Copy As you can set some parameters. Try put Off the visibility of some layers.
    In the latter case you can always adjust the DXF file in Autocad.
    Maria Manuela Pinho
    JimSteinmeyer
    02-09-2012 09:48 AM in reply to: MariaManuela
    Thank you,
    For the life of me I couldn't think of the term for tangent lline.
    Jim
    Inventor 2012 SP1
    HP G71 notebook
    Win 7 home premium
