• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *dave-gnus
    beginner trying to make perfect wire tetrahedron
    382 Views, 1 Replies
    10-31-2002 06:07 AM
    Howdy, I'm a beginner using IV4. I'm trying to construct an imaginary
    part: a perfect tetrahedron, 200mm on a side, made out of 1mm diameter
    wire. Each vertex of the tetrahedron should have three wire edges
    coming together at a point.
    I can make a triangle no problem:
    1. sketch a rough triangle
    2. make dimensions d1 and d2 both equal d0
    3. return and create a work plane perpindicular to original sketch:
    a. select "work plane" tool
    b. select one edge of triangle
    c. select one vertex of that edge
    5. create a sketch on the new work plane
    6. "project geometry" the coincident vertex into the sketch
    7. create a center-point circle centered on the vertex
    8. return and "sweep" the circle around the triangle
    I would like, as a next step, to create a work plane at the right
    angle to the plane of the triangle, coincident with the center of one
    of the lines. Unfortunately, I can't figure out how to do this. The
    work plane reference page in help says that to create a work plane at
    an angle, I select two parallel faces and enter an angle into an edit
    box. But since I don't have two parallel faces, I don't get an edit
    box. I've searched for another way to do the edit box, but haven't
    found it. I figure there must be a constraint-based way to acheive
    the tetrahedron.
    I have tried hacking my way to a solution:
    1. sweep out triangle as above
    2. create a work plane on the interface between the wires at a vertex
    by selecting three points around the edge of the vertex interface
    3. create a sketch in this work plane
    4. project the vertex into the work plane
    5. create a center circle with radius equal to the length of an edge
    (200mm). This is purely for construction purposes
    6. return and repeat steps 2-5 for a different vertex
    7. project circle created in step 5 into current sketch
    8. draw a point at the intersection
    9. return and create a work plane as the combination of the point
    from step 8 along with two vertices from the triangle in step 1
    10. create a sketch in the new work plane, project the vertices, draw
    another pair of edges, return, create a 1mm circular profile and
    sweep
    11. repeat step 9 with another pair of vertices
    12. repeat step 10 in the new work plane
    This does make a tetrahedron. The problem is that the vertices of the
    last step don't line up! I can't seem to make the work plane
    intersect the actual endpoints of the original triangle.
    I imagine that I could just put three triangles together with
    constraints in an assembly. But it seems like I should be able to
    acheive the same goal by just creating a part. Can anyone offer a
    simpler way to acheive this goal?
    Dave
    Please use plain text.
    *KJohnson
    Re: beginner trying to make perfect wire tetrahedron
    10-31-2002 08:50 PM in reply to: *dave-gnus
    In the sketch that you want it construct a construction line from mid point
    to mid point. Change the style in the drop down to construction. STart a
    line. hover and move the cursor over one of the sketch lines until the dot
    turns green this will be the midpoint. Now attach the other end to the
    opposite sketch line. You may have to but a horiz or vert constraint on the
    new line. Exit the sketch. Start a workplane and select the construction
    line you just made and a plane that is 90 deg to what you want. You should
    be able to specify an angle now. Good luck
    Kathy Johnson
    wrote in message news:m3n0ouw9c6.fsf_-_@bfnet.com...
    > the tetrahedron.
    > sweep
    > Thanks,
    > Dave
