• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor wh
    wh
    Betreff: ball pattern in BALL SCREW assembly
    10-19-2012 11:43 AM in reply to: lis_wang
    Here's my approach.
    I've made changes to spindle and ball screw, and made an array of the balls.
    In the end I tried to turn the spindle and move it through the ball screw, but no luck. I suspect, that this is another sample of Inventor's unsatisfying constraint capabilities.
    Remark: I know, that normally the balls are moving, too, but I neglected that, because of simplification. And I know, that normally the spindle is axially fixed and just rotating, and the ball screw does the axial movement. I'm in doubt, if this version would be running better.
    EOP of parts needs to be moved down. Files are Rel. 2012
    Walter
    Please use plain text.
    10-20-2012 05:23 AM in reply to: wh
    It is really a clever approach. By usin this method, I have to manually change the quantity of ball in BOM.
    Thank you very much
    wh
    10-20-2012 05:45 AM in reply to: lis_wang
    You can do the array as separate bodies as well, Lis.
    But unless you're in ball screw manufacturing, you're ordering complete elements. It doesn't matter, how many balls are inside.
    Walter
    10-20-2012 06:13 AM in reply to: lis_wang
    Pattern Component will give multiple instances of one ball.  (rather than having multiple balls in one part file)
    I have assigned this problem to my class.
    I will post my solution once they have attempted the solution.
    oops, I keep forgetting you are on 2012 - well I'll post a screen shot when they get done.
    Inventor Professional 2014 Edu 64-bit
    10-20-2012 08:15 AM in reply to: JDMather
    Thanks JD. I will try your approach as well.
    wh
    10-30-2012 12:06 PM in reply to: JDMather
    Did you try the solution with your class meanwhile, Jeffrey?
    10-30-2012 12:27 PM in reply to: lis_wang
    Ah yes, we came up with a good solution, but I forgot about this thread.  I will try to remember to attach the solution tomorrow.  (what is left of a hurricane is sitting right over the top of my head today)
    wh
    10-30-2012 01:32 PM in reply to: JDMather
    My best wishes for not too much damage by the storm.
    Good to see, that you still have access to electricity.
    10-30-2012 02:43 PM in reply to: wh
    My wife is peddling the bicycle generator as fast as she can.
    The wind has died down here, just some left-over rain.
    We didn't experience any damage on our property, but I haven't ventured down the road yet to check the neighborhood.
