Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ball pattern in BALL SCREW assembly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
May I know how to pattern the ball in BALL SCREW assembly? The ball screw assembly is attached.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As the file is big, so I posted here in two messages.
Re: ball pattern in BALL SCREW assembly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Really it depends on what you want to do with this.
The easiest solution is a curve driven pattern of Workpoints in the screw part and then use that pattern to place the balls in the assembly.
If your end goal is Dynamic Simulation then a bit more work is required.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do not undertand what you said. Could you please pattern the ball inside the nut. I do not do the Dynamic Simulation.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See Tips 43-47 here http://home.pct.edu/~jmather/SkillsUSA%20Universit
and also
the slot and the ball are the same size (no allowance for clearance and manufacturing tolerance) - we can't make perfect parts in the real world.
and also
the circle sketch for the coil is not perpendicular to the start of the helix - therefore the slot is not round in cross-section and there is interference between the ball and the screw and nut.
Start with a Natural start condition (off the end of the part far enough that only the helix is cut or use a single line Coil to create a surface body coil to use with Sweep. This will be needed to place and pattern the WorkPoints, so that is how I would do the part.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The blue "line" is your circle profile on edge view.
The purple curve is the Helix.
Notice that the blue line is not perpendicular to the start of the helix.
The orange "line" is a Workplane created perpendicular to the start of the helix.
very few people catch this mistake that results in incorrect geometry.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do not get what your mean. Is that possible give me the file, I take a look myself?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am using 2013 - so you would not be able to open my file even if I posted it.
In this image there are two circles - the 6mm circle you used with Coil to cut the face shown in orange.
I cut back overtop that feature (red) with a 5.99mm circle and notice that it cuts the sides more even though the circle is smaller.
My circle is perpendicular to the helix, yours is not.
I made a mistake earlier when I said one solution was Natural on the start of the Coil. That is the default. You would need a flat start to have the circle perpendicular to the coil curve. But don't use that technique unless you start the Coil well off of the part, and in any case it will give you results that are harder to understand than simply doing a Coil surface of a line and using the edge of the surface body helix for a Sweep.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just realized I left out some steps in that other document - see this one
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you please posted the file here? I will installed 2013 in another PC to try it.
