• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    slphantom
    auto project datum planes
    237 Views, 4 Replies
    07-13-2012 12:38 PM
    is there a way to auto project datum planes that are square to the sketch?
    just wondering.
    thanks
    Scott
    win 7 64 bit
    xeon cpu 3.2 GHz
    quad core
    12 gig of ram
    Autodesk product design
    suite premuim 2013 64bit
    Nvida quadro fx3800
    Space Pilot ver. 1.6.2 2010
    slphantom (NNTP handle: scottl)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as scottl
    Please use plain text.
    Re: auto project datum planes
    07-13-2012 01:14 PM in reply to: slphantom
    I wish there was, since this is my preferred method of constraining to the part origin.  Instead, I had to create part templates with the first sketch having the projected planes, one template each for sketching on the XY, XZ, & YZ planes (see attached).  I put the 0 in front of each template name so that they show up first in the list of templates.
    Curtis_Waguespack
    iLogic Project All Work Planes
    07-13-2012 02:35 PM in reply to: slphantom
    Hi slphantom,
    Attached is an example file with an iLogic rule in it that might work for you. If you create an external iLogic rule with this code you'll have it available to run on any file.
    Note that you need to be in a sketch edit for the rule to work.
    I hope this helps.
    Curtis
    If Typeof ThisApplication.ActiveEditObject Is Sketch Then
    'Do nothing
    Else
    MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
    Return
    End If
    Dim oPartDoc As PartDocument
    oPartDoc = ThisApplication.ActiveDocument
    Dim oSelectSet As SelectSet
    oSelectSet = oPartDoc.SelectSet
    oSelectSet.Clear
    'look at the workplane collection
    'and add each workplane to the select set
    For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
    oSelectSet.Select(oWorkPlane)
    Next
    'Project Geometry
    ThisApplication.CommandManager.ControlDefinitions.Item("AppProjectGeometryWrapperCmd").Execute
    'Cancels active command
    ThisApplication.CommandManager.StopActiveCommand
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Curtis_Waguespack
    Re: iLogic Project All Work Planes
    07-13-2012 02:57 PM in reply to: Curtis_Waguespack
    Here's another version that only projects Origin Planes.
    'Do nothing
    Else
    Return
    End If
    oSelectSet.Clear
    'find origin planes only
    If oWorkPlane.IsCoordinateSystemElement = True Then
    End If
    Next
    'Project Geometry
    Active Member
    02-28-2013 11:56 PM in reply to: Curtis_Waguespack
    Sorry for bringing back to life an older thread but I'm also interested in this functionality.
    What i'm interested in is: Is there a way to create a button on the ribbon (or a shortcut key) for this?
    Maybe a macro or something? (I'm not very familiar with macros, not sure if it would be possible or not...).
    Thanks in advance,
    B.
    (Inventor 2013).
