• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Valenti, Mark
    assy & boms...
    28 Views, 5 Replies
    11-13-2002 09:26 PM
    What determines the line number of a part in an assembly when you go to
    balloon it out? Is it order of insertion?
    Please use plain text.
    *Mike
    Re: assy & boms...
    11-13-2002 09:39 PM in reply to: *Valenti, Mark
    Yes. This can be changed by dragging BOM line up or down and then selecting
    renumber, this moethod is permanent. Or you can manually renumber them and
    select sort, however this method is not permanent and if you delete the BOM
    the numbers revert.
    "Mark Valenti" wrote in message
    news:8904F483E1AF0319E16416450366FFBC@in.WebX.maYIadrTaRb...
    *Hinterhoeller, Richard
    Re: assy & boms...
    11-13-2002 09:41 PM in reply to: *Valenti, Mark
    Mark:
    I believe it is the order in which they appear in the browser of the
    assembly.
    I have used this to my advantage by sequencing the parts in the
    assembly, then having the numbers assigned in the drawing the way I'd
    like them.
    Richard
    *Valenti, Mark
    Re:
    11-13-2002 09:43 PM in reply to: *Valenti, Mark
    THANKS FELLAS, THATS WHAT i THOUGHT.... EEK CAPS SORRY
    I was dimensioning.... I forget to turn em off.... oooh that would be a
    nice feature in inventor... a font of all caps so you wouldnt have to have
    capslock on. hmmmmmm
    "Richard Hinterhoeller" wrote in message
    news:3DD3A7EF.3090200@hfx.eastlink.ca...
    > Mark:
    > assembly.
    > like them.
    > Richard
    Re:
    11-13-2002 10:10 PM in reply to: *Valenti, Mark
    Mark:
    I did an end run around forgetting the caps lock - I switched to using
    lower case on my drawings. It makes them way easier to read. I know
    it's not ANSI but I figure those standards were based on hand-written
    letters, not computer type-set.
    Mark my words, this is the beginning of the revolution to change that
    standard.
    Richard
    *Valenti, Mark
    Re:
    11-13-2002 10:29 PM in reply to: *Valenti, Mark
    as this yankee says... "Oh (edited), another revolution...." wheres my musket?
