• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Contributor
    Accepted Solution
    agitator
    213 Views, 9 Replies
    12-11-2012 04:23 AM
    I am after a agitator part if anyone have available.This goes on a shaft driven  by a electrical motor.
    Sam
    Please use plain text.
    *Expert Elite*
    Re: agitator
    12-11-2012 05:18 AM in reply to: sam__gleeson
    Post screen shot or url of similar part.
    Valued Mentor
    mpatchus
    Re: agitator
    12-11-2012 10:39 AM in reply to: sam__gleeson
    Here's a real quick one I made up.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Contributor
    Re: agitator
    12-12-2012 03:36 AM in reply to: sam__gleeson
    Thanks Mike
    Here is a picture JD of a agitator
    Best Regards
    Sam
    Valued Mentor
    mpatchus
    Re: agitator
    12-12-2012 04:17 AM in reply to: sam__gleeson
    Oh THAT kind of agitator!   LOL
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Contributor
    Re: agitator
    12-12-2012 04:33 AM in reply to: mpatchus
    Very nice Mike...that was quick...do you have something similiar where the blades are egg shape instead of the straight blades
    Appreciated
    Sam
    Valued Mentor
    mpatchus
    Re: agitator
    12-12-2012 04:59 AM in reply to: sam__gleeson
    Sure, just used the same part and changed the way the LOFT is created.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Contributor
    Re: agitator
    12-12-2012 05:02 AM in reply to: sam__gleeson
    Hi Mike
    fantastic...thanks for the models...i will now practice
    Best Regards
    Sam
    Valued Mentor
    mpatchus
    Re: agitator
    12-12-2012 05:07 AM in reply to: sam__gleeson
    The straight bladed vane was created with two lofts.  One for the blade using two sketches for the blade profile, and another to connect the blade base to the hub, also using two sketches/profiles.
    The curved bladed vane was created with one loft using the three sketches. I also added a fillet to round the end of the blade.
    That's the only real difference.  If you compare the two part files you can see the process.  You can tweak the dimensions as required to achieve different results.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Contributor
    Re: agitator
    12-12-2012 05:17 AM in reply to: mpatchus
    Thanks Mike...very helpful
