• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    advanced surface
    156 Views, 11 Replies
    01-16-2013 09:47 AM
    hello there,
    I'd like to connect border shape with a point which is few milimeters above flat surface (see fig 1,2) but I do not want to do it as it was presented on fig.3
    it should be connected smoothly, something as it was presented on fig 4 & 5 if you know what I mean
    it should like a fragment of a really big ball which part of surface is smoothly fading down
    how to set advanced extrusion options? I can not figure it out
    Please use plain text.
    Distinguished Contributor
    LT.Rusty
    Re: advanced surface
    01-16-2013 10:02 AM in reply to: marcin.blaszczyk
    What you need is loft, not extrude.
    Take a look at my attached file.  You might need to do another extrude afterwards, to cut away some overhanging stuff, but this should give you an idea of how to do what you're trying to accomplish.
    ___________________________________________________________
    Product Design Suite Ultimate 2013
    Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
    Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
    01-16-2013 10:06 AM in reply to: LT.Rusty
    that was fast, thanks! i'm checking
    LT.Rusty
    01-16-2013 10:07 AM in reply to: marcin.blaszczyk
    My computer is busy thinking about a whole bunch of things right now, so I don't really have anything better to do for a few minutes.  :smileyhappy:
    01-16-2013 10:13 AM in reply to: marcin.blaszczyk
    marcin.blaszczyk wrote:
    it should like a fragment of a really big ball....
    If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved Surface rather than do a Loft.
    There are a number of surfacing tutorials in my signature.
    Most of them except the Vacuum Tutorial are a little out of date.
    01-16-2013 10:33 AM in reply to: JDMather
    "If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved"
    can you extend it a little bit because Loft option is not completely satisfying me regarding this shape?
    01-16-2013 10:36 AM in reply to: marcin.blaszczyk
    If you are asking for my help you will have to attach an ipt file here.
    LT.Rusty
    01-16-2013 10:40 AM in reply to: marcin.blaszczyk
    Is this closer to what you are looking for?
    01-16-2013 10:43 AM in reply to: JDMather
    ok, here's a file
     sphere constraint should be where the point is (on additional plane)
    thank you
    LT.Rusty
    01-16-2013 10:46 AM in reply to: marcin.blaszczyk
    what's the diameter of the sphere you want to use?
