• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    adsk file format
    715 Views, 35 Replies
    04-07-2009 06:31 AM
    Can anyone tell me anything about the adsk file extension which is to be coming out with inventor 2010?
    What are its's capabilities, benefits?
    Please use plain text.
    *Expert Elite*
    Re: adsk file format
    04-07-2009 06:45 AM in reply to: huycke
    What file extension? Can you be more specific?
    *Expert Elite*
    04-07-2009 06:51 AM in reply to: huycke
    someones been misinformed.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    04-07-2009 06:53 AM in reply to: huycke
    Yes, I was in a meeting with an Autodesk Rep last week and while discussing the upcoming release of Inventor 2010 I asked if in the new release of both Inventor and REVIT it would be possible to import in REVIT native IPT files from inventor and keep the parametric intellegence.
    He said...there will be a new adsk file format which will be more...."robust", ....that is all I know.
    *Dennis Jeffrey
    The file extensions are the same, and no, they will not be
    backward compatible, just like all the other modelers.
    Dennis Jeffrey, Autodesk Inventor Certified
    Expert
    Autodesk Manufacturing Implementation Certified
    Expert.
    Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
    AIP 2008 SP3,
    AIP 2009-SP1 PcCillin AV
    HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
    .8185
    XP Pro SP3, Windows XP Silver Theme
    href="http://teknigroup.com">http://teknigroup.com
    **Master
    04-07-2009 07:21 AM in reply to: huycke
    *.ADSK is an exchange file format used in the AEC Exchange part of Inventor 2010 to get products out to Revit. In Revit the *.ADSK file format is used to author files for use in 3D Civil and so on.
    Look up AEC exchange in the help for 2010 for more info.
    *Expert Elite*
    Mark_Flayler
    04-07-2009 07:22 AM in reply to: huycke
    The new .adsk extension is done through the AEC Exchange Application inside Inventor. The adsk provides more streamlined dumping to Revit Families.
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    http://blogs.rand.com/manufacturing/
    *Dennis Jeffrey
    04-07-2009 07:35 AM in reply to: huycke
    Sorry, forgot that one.... :smileyhappy:
    Expert
    Expert.
    AIP 2008 SP3,
    .8185
    *Patrick Miller \(Autodesk\)
    04-07-2009 12:28 PM in reply to: huycke
    As some stated, review the Help for AEC Exchange to
    read about .ADSK files. This file format allows you to share Inventor data with
    Revit MEP or AutoCAD MEP. The format includes the 3D solids, 2D views, AEC
    Exchange connector information, and meta data. When opened in Revit or AutoCAD
    MEP, that application only uses what is supported from that file.
    If exchanging data with Revit or AutoCAD MEP, don't
    forget to use shrinkwrap to simplify your data. It makes for smaller file sizes
    and the MEP applications typically don't need the detail that Inventor
    needs.
    Hope this helps.
    Patrick Miller
    Autodesk Manufacturing Industry
    Group
    Technical Publications - Subject Matter Expert
    Novi, MI
    Can
    out with inventor 2010? What are its's capabilities,
    benefits?
    *Dennis Jeffrey
    04-07-2009 12:41 PM in reply to: huycke
    I tested the file transfer in 2010. It appears that Revit
    Structure 2010 x64 does not support the adsk format.
    Expert
    Expert.
    AIP 2008 SP3,
    .8185
