• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    cratetechdesign
    addition of (For Drawing)
    100 Views, 3 Replies
    03-06-2012 11:40 AM
    I was working within a model already on file.  I made numerous change to the original model (and didn't save= first mistake).  I then imported a hinge file that contained two parts.  I place both parts in the model seperately.  I then constrained them to one piece within the original model.  I then created a piece of sheet metal.  I tried to manipulate the sheet metal with a flange, and it would not allow me to select an edge.  I then tried to constrain the imported hinge part to the new sheet metal, and it would not allow me to select the hinge part.  I thought it might be a glitch, so I saved, closed out, and reopened the file.  (second mistake.)  It was after I reopened the file that I noticed that it now says (For Drawing) after the file name.  Because I saved and reopened the file, I cannot back up to where this is not the case.  How do I get back to being able to manipulate the model?  Please help!  I'm on a deadline.
    Please use plain text.
    *Expert Elite*
    Re: addition of (For Drawing)
    03-06-2012 01:30 PM in reply to: cratetechdesign
    Attach your file(s) here.
    New Member
    cratetechdesign
    03-07-2012 08:20 AM in reply to: cratetechdesign
    Oh nevermind!  That is my own stupidity going on!  (For Drawing) is a level of drawing.  I'm still not sure why I'm having problem manipulating, but it has nothing to do with the (For Drawing).
    Valued Mentor
    CelticDesignServices
    03-07-2012 08:25 AM in reply to: cratetechdesign
    OK, I'm totally confused on this one.
    Are you still having issues trying to modify the model?
    Sounds more like a process issues as opposed to a software issue.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
