• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    adding color
    173 Views, 8 Replies
    10-06-2012 02:50 PM
    I have some shapes in which i want to add solid color to sections.I cannot find anywhere to accomplish this effect.Can this be done in Inventor 2013..it will be a 2D view
    Please view the attached 2013 file...can this be done
    Rich
    Please use plain text.
    *Expert Elite*
    Re: adding color
    10-06-2012 04:49 PM in reply to: richard_cirillo
    If it is 2D - why aren't you creating the sketch in idw or dwg?
    http://forums.autodesk.com/t5/AutoCAD-2013/symbols/td-p/3649346
    Active Contributor
    Re: adding color
    10-06-2012 06:34 PM in reply to: JDMather
    I use Inventor much more then Autocad (new) so if possible would rat5her do in Inventor
    Rich
    *Expert Elite*
    Re: adding color
    10-07-2012 04:43 AM in reply to: richard_cirillo
    If it is 2D - why aren't you creating the sketch in Inventor idw or Inventor dwg?
    Sketched Symbols might be the way to go.
    Active Contributor
    Re: adding color
    10-07-2012 05:02 AM in reply to: richard_cirillo
    Thanks..
    Yes you are correct....can the title block be removed from the bottom right hand corner
    Rich
    *Expert Elite*
    Re: adding color
    10-07-2012 05:15 AM in reply to: richard_cirillo
    Yes.
    Right mouse button in browser.
    Active Contributor
    Re: adding color
    10-07-2012 05:19 AM in reply to: JDMather
    JD Thank you
    1 final question....can the shapes be filled in with solid colors
    Rich
    *Expert Elite*
    Re: adding color
    10-07-2012 05:22 AM in reply to: richard_cirillo
    Yes.
    Hatch/Color Fill.   (Fill/Hatch Region)
    ....and why do I doubt this is the final question?   :smileysurprised:
    Active Contributor
    Re: adding color
    10-07-2012 05:25 AM in reply to: JDMather
    It is as i also just found it
    Rich
