• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    acinetengine16 error
    1454 Views, 10 Replies
    08-30-2010 07:00 AM
    I have been getting the acinetengine16 error on my computer lately.  I have traced it back to either Autocad or Inventor.  I have uninstalled/reinstalled, I have searched the NG I have done everything I can think of but to no avail.
    Can anyone give me a solution to this error.  It is annoying.
    Mark Smith
    Inventor 2009
    Please use plain text.
    Product Support
    Re: acinetengine16 error
    08-30-2010 09:48 AM in reply to: MarkSmith9762
    Mark,
    Did you try the steps mentioned in this technical article?
    Granted it is not the same error message but who knows if you can track down the location of the dll on your machine and feeding it to the registry...
    Bob
    Active Contributor
    08-31-2010 04:20 AM in reply to: bobvdd
    Bob,
    thnaks for the suggestion.  I searched the registry for the acinetengine16.dll file this morning and everything looks to be correct
    Mark
    Active Contributor
    09-14-2010 01:52 PM in reply to: MarkSmith9762
    HELP!!!!! This error is becoming more and more intrusive.  Surely someone from Autodesk has a solution to this problem.  Can anyone help me?
    Mark Smith
    Precision Devices
    Product Support
    09-14-2010 03:18 PM in reply to: MarkSmith9762
    Hi Mark,
    I found this related technical article in our knowledge base. http://usa.autodesk.com/getdoc/id=TS1068228
    Can you check if this is relevant to your situation?
    You could also helo us diagnose your problem by giving a little bit more details about your machine, Operating system and Inventor version you are using.
    Bob
    Active Contributor
    09-15-2010 05:58 AM in reply to: bobvdd
    bobvdd wrote:
    Hi Mark,
    Bob
    Bob,
    Thank you for your reply.
    I have read that article from the knowlege base in the past.  I am not using Zonealarm, I am using Semantic Endpoint Protection.
    My system is as follows
    Windows XP Pro sp 3
    Inventor Series 2009 sp 2
    Mark Smith
    Product Support
    09-15-2010 08:39 AM in reply to: MarkSmith9762
    Thanks for the extra info Mark.
    In Inventor 2009 , the expected version of this file AcInetEngine16.dll  is 17.2.56.0.
    Could it be that this file is corrupt or that you have a different version.
    Can you check the version number of the file via Properties > Details ?
    The file normally can be found under “C:\Program Files\Common Files\Autodesk Shared\” and  can be repaired by running a repair from the Control Panel.
    Bob
    Active Contributor
    09-15-2010 12:39 PM in reply to: bobvdd
    Bob
    Bob,
    It appears that the version of the file is correct.
    I tried to copy the dll from another machine that wasn't having the error but didn't work.
    How do you repair from Control Panel?
    Product Support
    09-15-2010 01:39 PM in reply to: MarkSmith9762
    In the Control Panel > Add or remove programs, expand the Inventor product  and hit the Change button.
    That will bring up the install wizard and you should see a Repair option.
    Be prepared it might take a while so maybe something to do at the end of your workday.
    Bob
    Active Contributor
    09-16-2010 11:25 AM in reply to: bobvdd
    Bob
    This too has failed.  It seems that I am looking at wiping my system clean and reinstalling everything.  I was hoping to avoid this method.
    Thanks for your help.
    Mark
