• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    RD-Digitek-USA
    Workstation for Product Design Suite Ultimate 2012?
    664 Views, 9 Replies
    09-08-2011 01:27 PM
    Hi All,
    I know this same question has been asked and answered many times before, but at the speed technology changes, I thought I would solicited the experience of this fine forum again.
    I have been stuck in the Solidworks world for the past 4 or 5 years. But am now with a new company and back on Inventor:-)
    I am specifying new CAD stations. We are using Autodesk Product Design Suite Ultimate 2012, but mainly Inventor 2012 64.
    Below are my minimum requirements so far.
    Did I miss anything?
    Do any of the specs fall short?
    Any other areas I can get a good value for the buck in?
    Also, I plan on getting quotes from Dell and HP. Are there any other companies I should be getting quotes from? We are trying to keep the price around $4000 +/-
    Windows 7 Pro 64
    Intel Xenon E5507 2.26 4MB/800
    Nvidia Quadro 4000 Graphics card
    16GB DDR3-1333 ECC RAM (with room to add more)
    500 GB SATA 7200RPM Hard Drive
    DVD+-RW
    22inch Widescreen LCD monitor 1920x1080
    24inch Widescreen LCD monitor 1920x1200
    Thanks in advance for your valued input
    Rick
    Please use plain text.
    Distinguished Contributor
    Re: Workstation for Product Design Suite Ultimate 2012?
    09-08-2011 02:11 PM in reply to: RD-Digitek-USA
    U should be crusing
    MikahB
    09-08-2011 02:20 PM in reply to: RD-Digitek-USA
    Per my (admittedly limited) understanding, there is no longer a need to use the Quadro OpenGL cards for Inventor.  Since Inventor is now DirectX, you're better off with a card that leverages that technology better.  A GeForce GTX 580 is a high-end DirectX card that costs about half the Quadro 4000 and will blow it away in DirectX benchmarks.
    Not sure about OpenGL and any of the other PDS Applications, but if Inventor has moved away from it, seems reasonable to assume that's the right direction at the moment.
    Going to be some nice machines!!  I'm about ready to replace my faithful "workstation in a bag" laptop.  It's amazingly functional but almost 3 years old now, time for new toys! :smileyhappy:
    Mikah Barnett
    All Angles Design
    Product Design Suite Ultimate 2014
    Windows 7 Professional x64
    Intel i7-3770k @ 4.5GHz
    32GB DDR3-2400 RAM
    GeForce GTX 670 4GB
    *Expert Elite*
    Mark_Flayler
    09-08-2011 02:41 PM in reply to: MikahB
    You shouldn't need a 500GB HD if you are using network storage and Vault, if you are doing a lot of local work, then that size is okay.  What would help there might be a Solid State hard drive instead for loading times.
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    http://blogs.rand.com/manufacturing/
    Valued Contributor
    09-08-2011 06:39 PM in reply to: RD-Digitek-USA
    I think there's a few components you could choose a bit smarter.
    For the processor, since Inventor is still mostly single threaded, you benefit from as much GHZ as you can get, and 2.26Ghz is not all that much.
    This E5507 is a cpu that does not have turbo boost technology, so It will never go faster than 2.26Ghz, and has no hyperthreading (where every core can do 2 threads), so can only do 4 threads (in Inventor 2012, only drawing view creation and rendering can do multiple threads)
    Also, I believe this E5507 is a cpu that can run in a dual cpu configuration. You pay extra for this functionality for the processor and the motherboard, and is a waste of money of you only keep the 1 cpu in your workstation.
    Instead, go for a single CPU workstation (like a Dell T3500), with a faster cpu like the Intel W3565 (4 core, 8 threads, 3.2Ghz, 3.46Ghz turbo boost), to give yourself a significant speed increase in just about everything you do in Inventor.
    For your budget you might even be able to get a W3670 (6 core, 12 threads, 3.2Ghz, 3.46 turbo boost).
    Harddrives are still one of the biggest bottlenecks in any system, so you want more speed there as well. The fastest would be to get an SSD as previously mentioned, but they're expensive. You won't need much space, so 120 or 160GB would suffice.
    I normally spec similar workstations with a 300GB 10K RPM drive. Another option would be to get a 1TB 7200rpm drive. You won't need that much space, but the bigger the drive, the higher the data density, the faster it reads data.
    As for the graphics, it's a neverending debate. For starters Dell doesn't let you configure a gaming card in their workstations.
    Since Inventor uses DirectX and not OpenGL that's one benefit of the Quadros gone. Other arguments would be that Quadros have better driver support, run cooler and quieter, and are designed to run 24/7 for years instead of a few hours every night. I usually spec Quadro 2000 cards and the 4000 for people who deal with larger assemblies, and have been happy with them.
    I would start with the following specs:
    Dell T3500
    3.2 Ghz W3565 4 core
    300 GB 10k RPM
    12 or 16 GB RAM
    Quadro 4000
    From that base bump the HD to an SSD first, if there's still budget left go to a 3.2 Ghz W3670 6 core or even a 3.46GHz W3690.
    For the display I'd get two 23" 1920x1080 (U2311H) or 24" 1920x1200 (U2412M) displays.
    I do find that prices quoted through our Dell business account are quite a bit cheaper than when you configure through their website, so what you can fit in your budget may vary.
    RD-Digitek-USA
    09-09-2011 05:23 AM in reply to: DVDM
    Thanks for the great feedback!
    This gets me so much closer.
    Valued Mentor
    jeanchile
    09-09-2011 07:57 AM in reply to: RD-Digitek-USA
    This blog post is kind of old but there is some good information here:
    http://ellipsis-autodesk.typepad.com/blog/2010/06/more-hardware-spec-goodness.html
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
    RayFeiler
    09-09-2011 08:08 AM in reply to: RD-Digitek-USA
    We just ordered four of these.
    Xi® MTower™ PCIe Workstation
    Intel® Core™ i7 980 3.33GHz 12MB Shared L3 Cache 1x4.8GT/s QPI Six-Core 12-Threads VT EM64T
    12228MB DDR3 @1333MHz Triple Rank Interleave
    nVidia® EVGA® GeForce® GTX 580 (Fermi) 1536MB GDDR5 PCIe SLI-Ready Dual Head 2xDVI-1xMini-HDMI PhysX™
    500GB 7200RPM SATA II 64MB Cache 4.2ms Latency WD RE4 Generation
    DVD+RW/DL/+R-R/CD-RW Double Media 4.7/8.5GB 18x w/Software-media
    Microsoft® Windows® 7 Professional Edition 64Bit
    EVGA® X58 SLI® 3 Intel® X58-2xPCIe 16x-Triple Channel DDR3 1333-1600+-1Gb Ethernet-2xUSB3.0-12xUSB2.0-2xSATA6Gb-6xSATA3Gb RAID 0/1/10/5-1394-HD Audio 8CH
    850W Corsair® TX Series Ultra-Quiet BB 12cm Fan 80%+efficiency 99% APFC UL
    $2,403.00
    Product Design Suite Ultimate 2014 64-Bit Update 1
    Sometimes you just need a good old reboot.
    Member
    TomSalomone123
    10-05-2011 07:25 PM in reply to: RD-Digitek-USA
    Hi Rick:
    I represent HP Workstations. You can easily configure a system for $4,000 that will work very well with Inventor. In our experience, we’ve found that Inventor performance is dependent on processing power, so you will benefit the most from high speed processors. If your primarily function is to design then you could order a Z400 with a W3670 3.2 GHz 12MB/1066 6Core CPU. This will give you additional cores for any rendering, analysis, simulation or animation (with hyper-threading this could act as 12 cores).
    The rest of the configuration would include NVIDIA Quadro 2000, which is excellent for Inventor, along with:
    12 GB (3x4GB) DDR3-133 ECC Ram
    1000 GB HDD 7200 rpm
    DVD +RW
    Windows 7 Professional 64
    ZR24w monitor
    You can visit www.hp.com/go/hpautodesk for more information, and call the SMB store for any special deals we are currently offering to save money. Please let me know if you have any other questions – I’m happy to help.
    Tom Salomone
    HP Workstation Representative
    10-06-2011 01:18 AM in reply to: TomSalomone123
    he could go with faster i7 cpu, SSD drive and do not need quadro....
    and loads of $$$ saved
    Ric
