• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Working with very old assy's in AIS2010
    115 Views, 3 Replies
    03-17-2010 01:46 AM
    Hello Everyone,
    I'd like to ask some help.
    I have to work on a very old assembly again, which I pulled out of the archives. This was made in 2003 or so, with maybe Inventor 5 or something.
    The problem is, Inventor 2010 could open this fine and converted everything into its new format and saved. Only after this, it turned out, some of the sub-assemblies in the model were "checked out" (sorry, if this is not the right word, I'm using a german version of inventor) and therefore it doesn't let me work with the model at all. I remember this has happened to me earlier too, it was something with the old types of single user or multiuser projects or something like that. I also remember I was using "inventor UnReserve" to remove these "checkouts", but it doesn't work anymore. (Probably because of Vista? Or because of X64? Or doesn't recognize IV 2010 files?)
    So, I have all the files, converted into 2010, but unable to modify some assies, UnReserve doesn't work, how else could I remove this stupid "checkout" thingy?
    Thanks in advance!
    Please use plain text.
    *Mike Maenpaa
    Re: Working with very old assy's in AIS2010
    03-17-2010 11:03 AM in reply to: bshbsh
    You didn't pull the .ipj file out of the archive too?
    Check the box "Enable creation of legacy project types", on the General tab,
    in Application Options.
    Create a Shared project.
    This should allow you to create a Shared .ipj, which would allow you to
    Check In the files.
    Mike
    wrote in message news:6355941@discussion.autodesk.com...
    Hello Everyone,
    files?)
    "checkout" thingy?
    Thanks in advance!
    Valued Mentor
    03-17-2010 11:55 AM in reply to: bshbsh
    here i have same issue with inventor 11
    to IV 2010
    but finally i have recreated assembly constraints and LOD'S
    Please mark this response as Problem Solved if it answers your question.
    Ravi Kumar MB,
    i7 860 Dell Studio XPS Win 7 64 bit 8Gb RAM
    Autodesk Product Design Suite Ultimate 2012
    Email: ravikmb5@gmail.com , skype id: ravikmb5,
    *Dennis Jeffrey
    03-17-2010 10:09 PM in reply to: bshbsh
    I have an old Windows 2000 box with Inventor 5.3, 7 & 8 Installed.
    Depending on complexity of the files, many older versions must be
    migrated gradually to absorb modeling kernel and feature changes.
    I'd never go from IV version 4 or version 5.0 directly to IV 2009 or
    above. Too many changes. Batch migration also seldom works when you skip
    too many versions.
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Subscribe to the free "The Creative Inventor Magazine now available at:
    http://teknigroup.com/CI-Subscribe-Login.asp
