• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Conneally, Nick
    Word Links
    57 Views, 9 Replies
    11-25-2002 03:21 AM
    I'm putting together an operators manual, and would like to incorporate
    linked objects from Word to Inventor for illustrations. What would be the
    best path to creating the link? Should I export to MD6 than link from Word
    to MD6. I tried this & ran into some errors.
    Thanks in advance
    Nick
    Please use plain text.
    *Dotson, Sean
    Re: Word Links
    11-25-2002 03:38 AM in reply to: *Conneally, Nick
    You mean the hyperlink in Word would open the Inventor file? If so then
    just select the IV file as the source for the hyperlink. You'll need to
    have the project preset however.
    If this is not what you meant...what exactly DO you mean ?
    Sean Dotson, PE
    http://www.sdotson.com
    ...sleep is for the weak..
    "Nick Conneally" wrote in message
    news:816610A22279E993CE127D9DDBA4A563@in.WebX.maYIadrTaRb...
    Word
    > Thanks in advance
    > Nick
    *Conneally, Nick
    Re:
    11-25-2002 03:58 AM in reply to: *Conneally, Nick
    No, I'm not claiming the hyperlink would open the file - just looking for
    the best way to use Inventor drawing files in Word for this manual. It
    would be great to have a link- but so far I'm not sure how. I tried with
    Insert - Object, no success (oh yeah, it links, but the link just opens the
    Inventor file, nothing appears in Word but the hyperlink itself). Word
    does give the options to insert an ACAD file, however no link would be
    present.
    Nick
    "Sean Dotson" wrote in message
    news:4075390C2ED7027322E329CB7146995C@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    the
    > Word
    > > Thanks in advance
    > > Nick
    Distinguished Contributor
    Re:
    11-25-2002 04:04 AM in reply to: *Conneally, Nick
    Everyone has their own opinions so take this for what it is worth. Our Tech. Writers feel that wireframe makes the most reproducible documents, they can be easily faxed etc. where shaded views don't come across so well. They create the views they want in Inventor and DXF out, then open them up in Autocad. I believe they then use wmf out from AutoCAD to put things in their Adobe software (Pagemaker I think, I don't recall for sure). I don't know why wmf was working better for them than inserting the DXF files, perhaps Adobe didn't have that option. - Rich
    Re:
    11-25-2002 05:47 AM in reply to: *Conneally, Nick
    IV --> Acad --> WMF --> MSWord.
    This is the way we do it for user manuals. Quite the pain, but best results. WMF format is a little more robust, kind of like a seudo vector graphic bit-map, akin to "rich text format" in the text and document world.
    IV --> BMP --> MSWord.
    Not happy with the resolution of end result. Otherwise works fine and quicker. Linking vrs embeding is flaky though. Don't know why and it dosen't help anyway if you expect the DOC to update with changes from IV. Output BMP is a new BMP file (not edited) which breaks the link.
    Print to PDF for other purposes.
    Why doesn't IV produce Jpg??
    Liscencing choke?
    jp
    *Dotson, Sean
    Re:
    11-25-2002 06:03 AM in reply to: *Conneally, Nick
    Why doesn't IV
    produce Jpg??
    Save to JPEG near bottom of screen
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    ...sleep is for the
    weak..
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    IV
    Not happy with the
    purposes.
    Liscencing
    choke?
    jp
    Re:
    11-25-2002 08:03 AM in reply to: *Conneally, Nick
    I don't know about Office XP but as near as I can tell the Office 2000 products expand a jpeg out so it takes up as much space as a BMP when you embed it. In other words if you take a 20 mb bmp and make a small jpeg in embed it in a powerpoint, word doc etc. you will get a 20 meg file. - Rich
    Active Member
    Re:
    11-25-2002 03:07 PM in reply to: *Conneally, Nick
    Hi There
    We do have a little program producing .jpg directly from IV.
    Pick 2 point (diagonal) and thats your .jpg file.
    Egon Rasmussen
    SikaMatec
    *Dotson, Sean
    Re:
    11-25-2002 09:38 PM in reply to: *Conneally, Nick
    There was a thread a while back named "Print
    Screen".  Glenn and I did an experiment...
    JPEG Size: 245
    BMP Size: 3841
    GIF Size: 299
    BMP Pasted into Word: 4,189
    BMP Inserted in Word: 173
    JPEG Pasted into Word: 5,335
    JPEG Inserted in Word: 266
    GIF Pasted into Word:1,846
    GIF Inserted in Word: 292
    Sean Dotson, PE
    ...sleep is for the
    weak..
    I
    Rich
    Re:
    11-25-2002 11:48 PM in reply to: *Conneally, Nick
    Now that is interesting. I tried it myself, the inserted bmp is actually smaller than the inserted jpg. In fact a 20 mb bmp inserted produced a 204 kb file and NO it isn't linked. Thanks for the tip - Rich Thomas
